What VIN code for LS differential
#876911
03/23/08 11:57 AM
I'm new to to this wesite. Just bought a 1990 trooper with a 2.8 v6 and auto tranny, I believe it's a 4L30E. I would like to know if anyone out there knows if you can determine if you have a factory limited slip diff. from your VIN. If so which number would that be? Tried doing a search, the info is probably allready on this site somewhere but I didn't find it. Thanks for any input. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: What VIN code for LS differential
[Re: tomjarz]
#876912
03/23/08 01:36 PM
Welcome to the site..... short answer, no, not on the VIN.... but look at your build options code plate (engine compartment firewall?) for G80, that'll indicate LSD.
HTH Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
P.S. Theres a link to all the option codes for Troopers on "ITOG" ... main page no longer works and I've got the link on the other computer... will paste later.
'94 Isuzu Pickup, 4x4 NEVER give up...
[Re: Van]
#876913
03/23/08 01:56 PM
Thank you Van, I checked the options plate and no G80. you wouldn't happen to know the gear ratio and wether ther is a shim installed on the ring gear? Original tire code is 9MV. <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: tomjarz]
#876914
03/23/08 03:47 PM
Here's the link, but main site is dead.... http://www.zitog.com/xr-001.shtmlVan <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Van]
#876915
03/23/08 05:07 PM
Unless you happen to have a fairly rare Trooper, your axle ratio is 4.56.
If your rig has around 200K on the speedo, there is a pretty good chance that even if you have a LSD, it is now toast. The clutches wear out, and there are more cost effective ways of addressing the issue than rebuilding a worn out LSD.
[Re: tomjarz]
#876916
03/24/08 01:08 AM
THAT TIRE CODE IS FOR 235 X 70 R 15 WHICH MEANS AS JIM STATED YOU HAVE A 4.55 REAR AXLE. JERRY
[Re: JLEMOND]
#876917
03/24/08 02:05 PM
Thanks again everybody. Great website!! <img src="/forums/images/graemlins/smile.gif" alt="" />
