94 xj studdering #877107 03/25/08 01:46 AM
E
el_d_m Offline OP
ok i picked up a 94 xj, 4.0/HO, 4x4. had an aftermarket oil pressure gauge on it & that caused the stupid check engine light to stay on. fixed that with a stock sending unit. just replaced the water pump ( it was leaking). flushed the radiator. all the vacuum lines are good. when the engine warms up & you are driving normally the engine begins to act like it wants to die. almost like a fuel issue. it idles just fine. fuel filter is good but i am going to replace it tomorrow.o by the way 210,000 miles or so.
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
Re: 94 xj studdering [Re: el_d_m] #877108 03/25/08 03:55 AM
BigJim Offline
Could be a coil.. They usually fail when warm.
Re: 94 xj studdering [Re: BigJim] #877109 03/26/08 10:48 AM
E
el_d_m Offline OP
cool gonna try that this weekend bj. just been swamped here with sick kids & work. i will let you know what happens.
Re: 94 xj studdering [Re: el_d_m] #877110 03/30/08 01:43 PM
E
el_d_m Offline OP
swapped out the coil & it ran like a champ again !! for 2 days then it wouldnt start like the timing was way out popping & whatnot. so we swapped the ecu & its running perfect now even stronger if thats possible.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5994 MB (Peak: 0.6547 MB) Data Comp: Off Server Time: 2026-06-01 23:28:03 UTC
