Re: Cracked heads?
[Re: 89montero]
#877638
03/29/08 03:35 AM
My heads were both cracked and I got reman heads on ebay for $300 shipped. They were minivan heads but worked just fine. and yes you can weld aluminum heads. Or should I say some people can, I cannot.
Re: Cracked heads?
[Re: HondaGuy]
#877639
03/29/08 04:16 AM
I'm going out to the junkyard this weekend. Anything I should look for before I start tearing engines apart?
1989 Montero 4dr V6 3.0l
Re: Cracked heads?
[Re: 89montero]
#877640
03/29/08 04:28 PM
We used to weld and straighten OHC Aluminum heads all the time. As someone else mentioned it needs to be super clean and heated in an oven. Good machine shops can do this without it costing an arm and a leg (i think we only charged 35-50 bucks for the welding, but then there was charges for installing new valve seats. We didn't really charge for removing the old seats as we would just cut them at the crack, then grind a v-groove in the crack anyway). We used an aluminum welder guy that made custom tanks and bottles (industrial stuff), he never welded automotive stuff until we approached him but he was good (and cheap...he'd see these little 1 inch welds and say $10 or $20). To straighten them we heated in an oven then we would set them up in a press and "bend" them the other way (we did a lot of measuring and setup but essentially just bent them the other way).
The crack he has may not have cracked all the way through yet, thus no indication from oil fouling or exhaust steam.
-Todd 1987 Montero 2.6l 5-speed (Sold...but I still miss her) 2008 Jeep Patriot Sport 4x4
Re: Cracked heads?
[Re: toddstidham1]
#877641
03/29/08 05:10 PM
It is nice to see others recognizing that OHC heads need to be straightened. I still hear so many times where someone just cuts a head and then wonders why belt life is rear short.
Re: Cracked heads?
[Re: OldColt]
#877642
03/30/08 08:16 AM
Or worse, the cam binds in the head after it's torqued down onto the motor. I've seen belts, cam gears, cam towers and the camshaft themselves all break from not straightening a head (amazing how much torque a starter motor has).
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6145 MB (Peak: 0.6796 MB) Data Comp: Off Server Time: 2026-11-17 11:29:55 UTCValid HTML 5 and Valid CSS
