Page 2 of 3 1 2 3
Re: want to run 36s safely on a 35 rear end [Re: BigJim] #877976 04/01/08 01:27 AM
mossyoaktj Offline OP
too bad i live out near cincy. what kind of mods would have to be done to use a 8.8 ford rear end or what about a chrysler 8.25. im leaving for the marine corps here before too long so mayb ei will just wait and buy a brand new 44 rear end with a locker or somethin
"GOT SOME MUD"
Re: want to run 36s safely on a 35 rear end [Re: BigJim] #877977 04/01/08 01:32 AM
oh yea just checked the cincinnati craigslist to see what all was there and posted today was a dana 44 out of a 99 wrangler for 400. going to try and get it friday.ill keep you all posted
"GOT SOME MUD"
Re: want to run 36s safely on a 35 rear end [Re: mossyoaktj] #877978 04/01/08 03:19 AM
BigJim Offline
Around here that 44 wont be available Friday... It would be sold within 8 hours.
Re: want to run 36s safely on a 35 rear end [Re: mossyoaktj] #877979 04/01/08 03:23 PM
DBL_DTY97TJ Offline
When you get one it's time to start thinking about gears...You'll want to go deeper than 4.10's for 36's.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: want to run 36s safely on a 35 rear end [Re: DBL_DTY97TJ] #877980 04/02/08 01:32 AM
(sad day) the guy sold that 44 today. i talked to him last and was told if the dude didnt buy it then it was mine.but unforantly it was sold,so im going to start saving. he does however have a set of 6in coils for a tj that came off his 99 for 150. i just have to peice together a long arm kit from there. so if he still has those i will be picking them up. as long as the dude dont buy them. i plan on going with wither a 4.10 or a 4.56
"GOT SOME MUD"
Re: want to run 36s safely on a 35 rear end [Re: mossyoaktj] #877981 04/02/08 01:50 AM
reepersteve Offline
Might want to check out 4.88.
01' TJ Wangler, 6" Ruff Country X Series, 35" x 12.5" Mickey Thompsons On 15 x 10" rims w/ simi Bead Lock, Matching Warn Bumpers, 9500xi Warn Wench, Tom Woods Drive Shaft And SYE, And A K+N Cool Air Intake. Still Improving
Re: want to run 36s safely on a 35 rear end [Re: reepersteve] #877982 04/02/08 02:12 AM
DBL_DTY97TJ Offline
or 5.12
Re: want to run 36s safely on a 35 rear end [Re: DBL_DTY97TJ] #877983 04/02/08 02:19 AM
BigJim Offline
Mossy you will be waaaay to high geared with either of those gear choices. With taller tires it will take MORE rpm to keep em turning that it does with shorter tires and stock gears. I wouldn't hesitate to go into the 5's and the 4:88 just might be too high..
Since you have a choice you should be VERY careful which you purchase. You will need to use high gear and with 4:56's it will be lost to you forever.
Re: want to run 36s safely on a 35 rear end [Re: BigJim] #877984 04/02/08 03:16 AM
heres a set of axlles i may be picking up this wekend if i can make them work easy.
http://cincinnati.craigslist.org/pts/626053492.html
right now i think i may go with a 1.25 body lift and run a 34x10.5 or a 35x10.5 or even 12.5
which would i better off with with the 4in susp. and maybe a 1.25 body for a total of 5.25
if theres anything i am misin glet me know please.thanks for all the help.
"GOT SOME MUD"
Re: want to run 36s safely on a 35 rear end [Re: mossyoaktj] #877985 04/02/08 03:43 PM
Brown81CJ5 Offline
You will have to do some mods to those axles to make them work...like retubing them. Those axles are from a narrow track Jeep like my '81. They will not be wide enough for '82 and later Jeeps.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6420 MB (Peak: 0.7490 MB) Data Comp: Off Server Time: 2026-11-03 04:52:21 UTC
