Page 1 of 3 1 2 3
want to run 36s safely on a 35 rear end #877966 03/29/08 05:17 AM
mossyoaktj Offline OP
well we are now to upgrade the tj to a set of 36 like the cj i just got my only concern is that the 35 in the rear wont hold it. the jeep is a dd. i know i can put a better rear end in it to help, but was wandering if i could go with a set of stronger axles and a locker to buff the rear end up a bit.. i was lookin at the super 35 with the locker for a little over 1k but was wandering if there was something else i could do to save money. the jeep is the 5spd 4.0 wrangler sport if you needed to know.thanks in advance
"GOT SOME MUD"
Re: want to run 36s safely on a 35 rear end [Re: mossyoaktj] #877967 03/29/08 01:36 PM
E
el_d_m Offline
better to look for a different axle than that 35. a dana 44 would be ideal. put a locker in that & a set of 4.10 gears front & rear & i think you would be doing good. but, it depends on the type of off-roading you plan on doing. at any rate lose the 35. its not worth the money to put in the super 35 kit. for that money you can beef up a better axle.
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
Re: want to run 36s safely on a 35 rear end [Re: el_d_m] #877968 03/29/08 03:35 PM
where should i look at to find a 44 for reasonable i can pull the 35 with no prob but how difficult would it be to install the 44
"GOT SOME MUD"
Re: want to run 36s safely on a 35 rear end [Re: el_d_m] #877969 03/29/08 03:38 PM
Brown81CJ5 Offline
If you want to run the 36's on that axle....get the upgraded shafts (still a waste of money in my opinon), but do NOT get a locker. Adding a locker will just put you right back where you are with the stock shafts, except that the damage that COULD be caused will be more expensive...i.e. exploding your locker, aftermarket shafts, etc.
Run the 36's with an open diff, and when that axle fails, upgrade to a 44.
Call around to some junk yards to see if they have any Jeeps that have been wrecked in just the front. If you have no luck with that, then just ask if they have any Jeeps at all, and if they know what axles are underneath them.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: want to run 36s safely on a 35 rear end [Re: mossyoaktj] #877970 03/29/08 06:54 PM
E
el_d_m Offline
try craigslist.com for decent deals & ebay is usually good here & there. junk yards are a strecth here in florida but may be better elsewhere. you should be able to find a 44 that will fit easily . try google too LOL you never know.
Re: want to run 36s safely on a 35 rear end [Re: mossyoaktj] #877971 03/30/08 09:05 AM
BobRowe Offline
I wouldn't try either 35s or 36s on that D35. Don't spend the money trying to build it up. Go with either a D44 or a Ford 8.8.
Re: want to run 36s safely on a 35 rear end [Re: BobRowe] #877972 03/30/08 05:21 PM
yeah. i use to have an 8.8 in the explorer but that was before i i had the jeep.seeing how i dont exactly the moneyu to buy a 44 right now unless i come across one for a reasonable deal i will probably go with the 34x10.50 ltbs.theyre only a few lbs heavier.plus that gets me almost another inch out of it. i am planning on lockin the rear. would it be safe to do so with the 34's. i dont really do that hardcore of offroad seeing how theres is nothing close around to really go to. big rock closed down,badlands is 3-4 hours away. if theres anymore info let me know.
"GOT SOME MUD"
Re: want to run 36s safely on a 35 rear end [Re: mossyoaktj] #877973 03/30/08 08:42 PM
BobRowe Offline
Iwouldn't spend the mpney on a locker for a D35. Save up a few more bucks and get a 8.8 in there.
Re: want to run 36s safely on a 35 rear end [Re: BobRowe] #877974 03/30/08 10:29 PM
E
el_d_m Offline
take your time & keep pocketing cash keep an eye on sites like ebay & craigslist . you can find a good 44 or 8.8 on there at a decent price. save your $ & dont lock up that 35.
Re: want to run 36s safely on a 35 rear end [Re: el_d_m] #877975 03/31/08 08:24 PM
BigJim Offline
Here ya go Mossy Look for something like these and go first class..
http://austin.craigslist.org/pts/625336507.html
http://austin.craigslist.org/pts/624957307.html
http://austin.craigslist.org/pts/625115521.html
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.009s) Memory: 0.6382 MB (Peak: 0.7621 MB) Data Comp: Off Server Time: 2026-11-14 21:30:36 UTC
