Big Bosch fog lamps on a 95 SR #878100 03/29/08 10:23 PM
scottiesharpe Offline OP
I made a neat modification today on my 95 SR. I have never been too happy with the light output of the fog lamps. They are high quality Bosch units, but they don't put out much light. Maybe they are too small.
Anyway I had a larger pair of Bosch fogs that I took off a junk BMW that are larger and have great output. I think they are called the "Pilot" series. I wanted to put them on the SR. They have the same mounting system but they are bigger.
I removed the scrape pan and removed the old lamps. I left the brackets and mounted the new lamps. They went right on. But now the pan wouldn't fit.
Two things are wrong: The plastic grille needs to be trimmed away. This is easy and it will be obvious where to snip it. I used tin snips and sanded the edges smooth.
Now that the lamps fit in the grille holes, the pan won't mount. It needs to be a little lower. So I made some small spacers out of steel tube. The spacers are about 1/2" long. I put washers on either side of the spacer and also replaced the front bolts on the pan with longer ones. The rear bolts needed no modification.
Bolt it all together and it looks pretty good!
Light output is much improved!
Pics:
Scottie Sharpe
Sunny San Jose CA
Webmaser for BMW TURBOS! Forum
http://bmwturbos.scottiesharpe.com
1995 Montero SR
Re: Big Bosch fog lamps on a 95 SR [Re: scottiesharpe] #878101 03/30/08 04:46 AM
redbull Offline
I like it, looks good! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Big Bosch fog lamps on a 95 SR [Re: scottiesharpe] #878102 04/01/08 11:01 PM
3
3esso Offline
Niiice, very nice upgrade <img src="/forums/images/graemlins/kewl.gif" alt="" />
I copying that soon <img src="/forums/images/graemlins/smile.gif" alt="" />
96 NJ SWB 3.5 pajero(Bone stock)
84 NA Hi-roof Pajero(also Stock)
Re: Big Bosch fog lamps on a 95 SR [Re: 3esso] #878103 04/02/08 01:09 PM
Mad_Scientist Offline
Yeah, that does look good. My factory fogs are half full of mud right now <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Big Bosch fog lamps on a 95 SR [Re: Mad_Scientist] #878104 04/02/08 11:04 PM
torquemonster Offline
I've been wanting to do the exact same mod but wasn't sure how it would look..thanks!! I know what im doing now!
Re: Big Bosch fog lamps on a 95 SR [Re: torquemonster] #878105 04/03/08 02:06 AM
COOL!!
Glad you like it guys! <img src="/forums/images/graemlins/wink.gif" alt="" />
Post some pics of your rig once you do it!
Scottie Sharpe
Sunny San Jose CA
1995 Montero SR
Re: Big Bosch fog lamps on a 95 SR [Re: scottiesharpe] #878106 04/03/08 03:45 AM
89montero Offline
looks great! I recently put a pair of KC slimlites(titanium/ice bulbs) and it made a huge difference in the front end appearance.
1989 Montero 4dr V6 3.0l
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6185 MB (Peak: 0.6939 MB) Data Comp: Off Server Time: 2026-06-19 01:16:33 UTC
