crazy 99 xj #878596 04/02/08 12:14 AM
the_other_guy Offline OP
So the problems started in the beginning of february when I got stuck in the mud. I cleared the water out of the engine, but other things started to go wrong. The jeep would not idle, and it would cut out at high speeds. I had to change the tps, and spark plugs, and got that taken care of. Now it still runs kind of wierd.within a few minutes after I start the engine, every time I run the car, it will act sluggish, and the throttle will be really un responsive while starting to accelerate, or cut out during acceleration. that will go away within 5 minutes, but when the jeep idles for any length of time, it will act strange. The rpms will sometimes jump up, or drop down, almost to the point of dying, and the car will sound funny, and smell really bad. I changed the ignition coil last night, and it didnt help at all.
any ideas?
Your road to glory will be rocky, but fulfilling.
- Panda Express fortune cookie
94 YJ. no lift...YET
Re: crazy 99 xj [Re: the_other_guy] #878597 04/02/08 02:21 AM
BigJim Offline
If you have a ox sensor in the exhaust I'd be looking there.
Re: crazy 99 xj [Re: BigJim] #878598 04/02/08 10:42 AM
E
el_d_m Offline
got to love that mud!!! check to make sure you didnt unplug a vac line. 99xj have the ecu behind the driver's headlight right? my 93 does & that was a huge issue. there is always that fuse box under the hood that isnt exactly mud proof. LOL
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
Re: crazy 99 xj [Re: the_other_guy] #878599 04/04/08 03:57 PM
jrmoore76 Offline
So, it seems to me you might have the same problem as me. I didn't go mudd'in though. Mine started acting up after a long drive. Read my post "1993 Jeep Grand Cherokee Rough Idle and No Power PLEASE HELP" It will at least tell you what not to change. If you fix that issue definately let me know what magic you used on it. I will return the favor.
So you think your tough?
James
Re: crazy 99 xj [Re: jrmoore76] #878600 04/05/08 04:59 AM
My dads friend did an in depth scan on it, and the front O2 sensor was malfunctioning. It was telling the computer that the engine was running too lean, so the computer would richen the mix, then the engine would end up running way too rich. I just bought a new O2 sensor. I will let you know how it turns out once I install it.
Re: crazy 99 xj [Re: the_other_guy] #878601 04/05/08 10:37 PM
Well, from what i can tell from driving it around last night, and today, the new front O2 sensor did the trick.
Re: crazy 99 xj [Re: the_other_guy] #878602 04/06/08 06:09 PM
jrmoore76 Offline
It was the fuel pump for me. I broke down and bought one sunday and put it in now it works fine. <img src="/forums/images/graemlins/cheers.gif" alt="" />
James
Re: crazy 99 xj [Re: jrmoore76] #878603 04/06/08 07:36 PM
I wouldn't doubt that that could be a problem for me too, i just dont want to spend the money to buy one right now. <img src="/forums/images/graemlins/pfft.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6201 MB (Peak: 0.7147 MB) Data Comp: Off Server Time: 2026-06-08 17:52:19 UTC
