I need help figuring out a engine noise on my 2.6
#879164
04/06/08 01:42 AM
I have a noise that my 2.6 is making that sounds like a little squeek/squeel. The best I can describe it, it sounds just like a old VW Beetle, you know that little whisle/squeek that comes from the exhaust. I can hear it at the header and I can hear it al the way back at the tail pipe. I have adjusted the rockers thinking it might have something to do with it but even though they were way out, it did not fix my problem. Any sugestions?
Thanks, Chad
-Chad
Re: I need help figuring out a engine noise on my 2.6
[Re: 4xToy]
#879165
04/07/08 04:25 PM
You don't mention when you hear this noise. Is it anytime the motor is running? Under acceleration?, Braking?
It could be a broken weld, broken motor mount or anything that is causing a metal on metal "squeak". Check your exhaust hangers, spring hangers. I had a broken weld on a rear spring hanger that took me a while to figure out. Just caused an annoying squeak. Until I saw the rust, I couldn't find it.
[Re: lttlbddy]
#879166
04/08/08 12:01 AM
It happens all the time. More so when it the engine is cold. The noise is deffinately internal. It increases slightly when accelerating and then tapers off at certain RPMs. I am almost convinced it is just the normal sound of the engine since it is very unrestricted in breathing. Plus It runs perfect, has plenty of power and runs smooth
-Chad
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5932 MB (Peak: 0.6470 MB) Data Comp: Off Server Time: 2026-06-06 03:24:58 UTCValid HTML 5 and Valid CSS
