Page 2 of 4 1 2 3 4
Re: Adjust/Reprogram speedometer? (Bigger tires) [Re: DennisThompson] #879477 04/10/08 06:47 AM
DamKia Offline
Kia Moderator
oops, 100=116 not 100+,116. It doesn't matter how many time I [color:"white"]prof[/color] read I always miss something.
Dennis
Yeah, we noticed <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Adjust/Reprogram speedometer? (Bigger tires) [Re: DamKia] #879478 04/10/08 06:53 AM
Hydra747 Offline
I still say, that "It Doesn't Worth It!!!" <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: Adjust/Reprogram speedometer? (Bigger tires) [Re: Everet] #879479 04/12/08 05:16 AM
jaboo5322 Offline
I thought the difference would be alot more. With 31 10.5 tires, the police display they set on the side of the road says at 25 miles per hour, i'm actually at 28. Was not aware of more difference at higher speed.
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: Adjust/Reprogram speedometer? (Bigger tires) [Re: jaboo5322] #879480 04/12/08 07:25 AM
Nukeiridium Offline
I agree, "It Doesn't Worth It!!!"
CLASSIC <img src="/forums/images/graemlins/smile.gif" alt="" />
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: Adjust/Reprogram speedometer? (Bigger tires) [Re: DamKia] #879481 10/21/08 06:21 PM
BAZINGA Offline
There is a kit sold in Oz that does speedo corrections, 1% at a time from -99% to +99%, available here
Any idea on how to connect this? What wires etc?
99 Auto Sportage. Wildcat Extractors, Lukey Turbo Muffler, Warn manual hubs, K&N Air filter, Tyres 30/9.5/15, Ironman 40mm springs, KYB front struts & rear shocks, GME TX3220 UHF radio, dual battery system. Twin 10" electric fans. Next Job: Body lift
Re: Adjust/Reprogram speedometer? (Bigger tires) [Re: BAZINGA] #879482 10/21/08 08:14 PM
Everet Offline
If it is anything like the one I was talking of, you cut the vss output wire and connect the vss side of the wire to the IN and the speedometer side wire to the OUT.
Everet
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Adjust/Reprogram speedometer? (Bigger tires) [Re: Everet] #879483 10/21/08 08:23 PM
BAZINGA Offline
what is the vss wire?
Re: Adjust/Reprogram speedometer? (Bigger tires) [Re: BAZINGA] #879484 10/21/08 09:48 PM
Everet Offline
Vehicle Speed Sensor. It replaces the speedometer cable and feeds electric impulses to the ecm and speedometer.
If you have a manual with wiring diagrams, you should be able to trace it out.
Re: Adjust/Reprogram speedometer? (Bigger tires) [Re: Everet] #879485 10/21/08 09:52 PM
BAZINGA Offline
I could if I was a rocket scientist! I will need a little help. I do have the wiring diagrams, but what and where do I look for? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Adjust/Reprogram speedometer? (Bigger tires) [Re: BAZINGA] #879486 10/24/08 10:30 AM
BAZINGA Offline
Can someone supply more information please?
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6400 MB (Peak: 0.7482 MB) Data Comp: Off Server Time: 2026-11-02 08:03:57 UTC
