Carbuater trouble! #879545 04/07/08 08:09 PM
RaiderRascal17 Offline OP
I dont know what kind of Carburater is on my raider. My enigine is the 2.6 4-cyl.
Re: Carbuater trouble! [Re: RaiderRascal17] #879546 04/07/08 08:31 PM
CapnCrunch Offline
If it's the stock carb, it's a Mikuni. They are a bear to get running right if it sits for a while without being run. Once they do run correctly, however, they run fantastically on the trail. They handle radical angles very well.
If you're looking for a reman, I got one from FC Products a couple years ago and it's performed superbly since then.
Where in Colorado are you? I'm in Colorado Springs.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: Carbuater trouble! [Re: CapnCrunch] #879547 04/07/08 08:37 PM
Evergreen
i want to put a carburater main body on it but website says that it will only work on a Holly 650
Re: Carbuater trouble! [Re: RaiderRascal17] #879548 04/07/08 09:37 PM
LRJ4x4 Offline
I'm having a hard time following this conversation? What does a Holley 650 have to do with anything?
Re: Carbuater trouble! [Re: LRJ4x4] #879549 04/08/08 01:11 PM
toddstidham1 Offline
I think RaiderRascal got some bad info. Or maybe crossed with the Caravan 2.6 info? Some of those models had Holley's on them didn't they?
Like the Cap'n said, it should be a Mikuni two barrel on there unless a previous owner switched it out. Can you tell us what carb you currently have?
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: Carbuater trouble! [Re: toddstidham1] #879550 04/08/08 06:29 PM
im not sure what kind of carburater is on there now but the original owner did have an extra. He said he switched out right before i bought it, but the 2 look the same.
Re: Carbuater trouble! [Re: RaiderRascal17] #879551 04/08/08 07:32 PM
Photos needed... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Carbuater trouble! [Re: rxinhed] #879552 04/09/08 12:23 AM
don Offline
If it looks like this (ignore the arrows) from the front, on the passenger side, with the air cleaner removed: it's the stock factory Mikuni carb.
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: Carbuater trouble! [Re: don] #879553 04/09/08 03:51 AM
ok thank you now i just need to know if i can put a holly 650,750,850 or 950 on it to add more hp
Re: Carbuater trouble! [Re: RaiderRascal17] #879554 04/09/08 06:07 AM
LRJ4x4 Offline
Carbs don't add HP, They mix fuel and air at 14:1 ratio thats it!. The only bolt in replacement for the Mikuni is the Weber and those that claim it runs better are comparing the 20 year old Mikuni against a new Weber.
There is no quick fix for HP for the Raider unless you go turbo. Everything else is a solution looking for a problem <img src="/forums/images/graemlins/cyclops.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6418 MB (Peak: 0.7458 MB) Data Comp: Off Server Time: 2026-06-17 15:24:24 UTC
