1996 isuzu Rodeo 3.2 #879557 04/07/08 08:26 PM
L
lowflying90 Offline OP
what is the difference between the 1993 isuzu trooper 3.2 and the 1996 rodeo 3.2? is the block head the same just with different electronics and sensors? i would like to swap the 93 motor into the 96 if its possible.
jeff
Re: 1996 isuzu Rodeo 3.2 [Re: lowflying90] #879558 04/08/08 01:00 AM
JLEMOND Offline
what is the MAIN difference between the 1993 isuzu trooper 3.2 and the 1996 rodeo 3.2? is the block head the same just with different electronics and sensors? i would like to swap the 93 motor into the 96 if its possible.
jeff
THE CRANKSHAFT IS THE MAIN DIFFERENCE IN THE ENG ITSELF , AND THEN THE ELECTRONICS , BLOCK AND HEADS ARE IDENTICLE AS FAR AS BOLTING ON IN PLACE OF ONE ANOTHER, HOWEVER THE EX MANIFOLD IS DIFF, , THE BOLT PATTERN ON THE HEAD IS DIF WHERE THE MANIFOLD BOLTS UP, AND THE MANIFOLD ON THE 96 IS ALLSO A 3 BOLT WHERE THE HEAD PIPE BOLTS UP, THE DIFF IN THE CRANKS SHAFT IS THE TONE RING ,OR CRANKSHAFT SENSER AS IT IS CALLED ON THE 93, IT IS GROUND INTO THE SHAFT , ON THE 96 AND LATER IT IS A MACHINED RING THAT IS PRESSED ON TO THE CRANK, JERRY
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5864 MB (Peak: 0.6342 MB) Data Comp: Off Server Time: 2026-06-21 01:01:06 UTC
