1990 22r problems
#880070
04/10/08 10:00 PM
It wont pass emissions, we've narrowed it down to a few things... the HC is high... what would cause that? Clogged cat?
Also, is there an o2 sensor/emissions computer in the 90' 22r's? (or is there supposed to be?)
89 4Runner 3" BL, M/T locks, 33"bfg mt, bilstein, Kayline, tubebumper, toyotafiberglass panels TBI: Elocker,3.4 w/ORS,b+b,S2Sstg2cams,arias pistons,P+P intake,TRDs/c,URDpullies+7th,downey headers,MAPECU2,WEGO WB, SupraMAF,walboro255,stg4clutch, EPaOo2 sim
Re: 1990 22r problems
[Re: Greg_Canada]
#880071
04/11/08 04:46 AM
My Calif. 84 22r had a computer & an O2 sensor, so I'd expect a 90 to have them too.
[Re: Greg_Canada]
#880072
04/11/08 04:58 AM
Yes it is in the PS kick panel, will not run without it. <img src="/forums/images/graemlins/smile.gif" alt="" />
"Serenity through Sobriety"
[Re: Greg_Canada]
#880073
04/11/08 05:01 AM
Greg, to clarify, is that thing carbed or EFI? Last carb in the US was '87. (term 22R v. 22RE)
You can run the VIN thru carfax and see what they have in the database for it originally, if it's in there.
High HC for carb typically is the AAP or the cat. If your dipstick smells like fuel, make sure you change your oil and filter before going back in once you fix things.
[Re: kewlynx]
#880074
04/11/08 05:45 AM
Carbies were available until 1991 in the non sr5 2wd trucks.
[Re: Greg_Canada]
#880075
04/11/08 08:11 AM
High HC's is caused by an incomplete fuel burn or from running rich. What are the numbers? A new cat can knock the HC's down abut 100 or so and would be the cheapest place to start when you start replacing items. A failing/lazy O2 sensor will also cause it to run rich. You should also pull and check the EGR valve and PCV valves either if those get clogged it can also cause rich conditions. If you do have a 22re and not 22r an air leak in the intake after the AFM will also cause it to run rich.
[Re: Snowtoy]
#880076
04/11/08 02:10 PM
It's a 22r.... carbie, we bumped the timing up a bit and the truck ran alot better. havent done the e-test since doing that. Can timing effect HC? Also, there is no o2 sensor, there is a pipe welded in place of where the o2 sensor is in a normal truck, still havent found the wiring for it..... oh also a full tuneup was just done on the truck... I will get some more info later in the day, it's a friends truck...
[Re: Greg_Canada]
#880077
04/11/08 09:11 PM
Is it a factory weld over the O2 bung, or is it a private job. If factory does Canada emissions require an O2 on your carb'd '90?
Since it is carb'd, there is an air injection valve(at least on the older ones), that adds air to the exhaust gasses to help burn the unburnt fuel. If this is bad you will also get higher HC's than normal, which a new cat will not fix.
Timing can effect fuel burn and cause higher HC's, though I am not sure how much.
Did it fail at both idle and 2500 or dyno tests?
[Re: Snowtoy]
#880078
04/12/08 10:55 PM
Just for reference, I have an "84 4Runner with a booger weld over the O2 sensor mount, but I found the single wire wrapped up on the driver's side inner fender near the coil. Wasn't easy to find among the thousands of crappy innovations the previous owner did.
[Re: Greg_Canada]
#880079
04/14/08 08:32 PM
Mine failed on high HC on idle last year. Dealer told me I needed a new cat but a set of plugs and wires and some ethanol-blend gas did the trick. If you can't get the gas, dump a bunch of gas-line anti-freeze in.
1989 4Runner Special Edition 22RE, 5-spd. TG 3" SAS, MC DuaLs, 4.56s, Air Locker Hi-Clearance panels by www.toyotafiberglass.com
