Re: Asian Company (suspension) [Re: Hydra747] #880248 04/19/08 03:07 PM
Hydra747 Offline OP
Hey,
Does anyone know if one was to get a 50mm Fork......What strut would you get?
(It should be shorter right)? <img src="/forums/images/graemlins/confused.gif" alt="" />
And how much higher would the front end be?
What mods would be needed?
Suspension upgrades! <img src="/forums/images/graemlins/oink.gif" alt="" /> <img src="/forums/images/graemlins/oink.gif" alt="" /> <img src="/forums/images/graemlins/oink.gif" alt="" />
Thanks, Mike R. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Asian Company (suspension) [Re: Hydra747] #880249 04/19/08 03:28 PM
DEFBOY35 Offline
you would still use the stock strut, that is how you get your lift.
50 mm is 2 inches longer, so it would be the same as adding the 2 inch spacers. which i think is a 4" lift. i was going to get these if i could get ahold of them, and then build all my dif drop brackets and drop the lower control arms and have the knuckles modded to have a big ifs lift.
but gave up on that after a few months of trying to get ahold of them.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: Asian Company (suspension) [Re: DEFBOY35] #880250 04/19/08 03:52 PM
Hydra747 Offline OP
So, with the RSG front strut adapter.....Would you keep that?
Maybe I am overthinking the simple geometry here......The front strut would be the same then ---and the brake line prolly would be stretched only?
So in all it would be a 6" total front lift?
Re: Asian Company (suspension) [Re: Hydra747] #880251 04/19/08 05:38 PM
wyodriver4 Offline
k i just want to make sure im understanding. you are asking if you could put a 2" spacer on top of the rsg front lift for a total of 6" of lift? what would you do for the back, areostar springs? i think that would be way cool if thats what you mean, but it may get awful tippy.
cone filter, boche platinum 4 plugs, 235/75/15 kumho all terrains jeep tj rear springs and rav 4 rear shocks, rocksport gear 4" front springs, warn manual hubs, 2.25 inch exhaust, no cat, 48" thrush glasspack
Re: Asian Company (suspension) [Re: wyodriver4] #880252 04/19/08 05:58 PM
DennisThompson Offline
The longer forks will do the same thing that my spacers do except on the other end, 4inches is still about the max lift you should go without lowering your front diff, the CV axles just cant take any more of an angle. Adding to the forks will cause problems so I would use the stock struts and springs. Daves Rocksport lift gives as much travel as shown on the pic on that website. Except for that 5.38 gears you can get the lifts here in the US from people you can get in touch with. It does look like quality stuff though.
Dennis
Re: Asian Company (suspension) [Re: Hydra747] #880253 04/21/08 05:12 AM
sportagebandit Offline
in china they speak manadarin or cantonese /in korea they speak korean.
One should also use proper "capital letters" where appropriate! <img src="/forums/images/graemlins/lol.gif" alt="" />
Thanks for the info on the language issue! <img src="/forums/images/graemlins/cheers.gif" alt="" />
I sent an E-mail and am awaiting a response.........
Tried to call but did not get past the country code problem? <img src="/forums/images/graemlins/confused.gif" alt="" />
We will see what becomes of the e-mail aspect <img src="/forums/images/graemlins/sleeping.gif" alt="" />
iN cHINA tHEY sPEAK mANDARIN oR cANTONESE /iN kOREA tHEY sPEAK kOREAN.
BeTtEr... <img src="/forums/images/graemlins/notooth.gif" alt="" />
96 SPORTAGE 4 DOOR:1 3/8 body lift:eibach springs & spacers:15x8 rockcrawlers & 31x11.50 super swampers:warn hubs:winch bumper http://www.cardomain.com/ride/2115301
Re: Asian Company (suspension) [Re: sportagebandit] #880254 04/21/08 02:36 PM
Hydra747 Offline OP
WISE GUY HERE? <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Asian Company (suspension) [Re: Hydra747] #880255 04/21/08 08:27 PM
hehe
btw the only company (overseas) that i have been able to get a hold of is automation king. which is the company in taiwan that makes a snorkel for the sportage.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6310 MB (Peak: 0.7325 MB) Data Comp: Off Server Time: 2026-06-09 23:39:57 UTC
