Re: Asian Company (suspension)
[Re: Hydra747]
#880248
04/19/08 03:07 PM
Hey,
Does anyone know if one was to get a 50mm Fork......What strut would you get?
(It should be shorter right)? <img src="/forums/images/graemlins/confused.gif" alt="" />
And how much higher would the front end be?
What mods would be needed?
Suspension upgrades! <img src="/forums/images/graemlins/oink.gif" alt="" /> <img src="/forums/images/graemlins/oink.gif" alt="" /> <img src="/forums/images/graemlins/oink.gif" alt="" />
Thanks, Mike R. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Hydra747]
#880249
04/19/08 03:28 PM
you would still use the stock strut, that is how you get your lift.
50 mm is 2 inches longer, so it would be the same as adding the 2 inch spacers. which i think is a 4" lift. i was going to get these if i could get ahold of them, and then build all my dif drop brackets and drop the lower control arms and have the knuckles modded to have a big ifs lift.
but gave up on that after a few months of trying to get ahold of them.
[Re: DEFBOY35]
#880250
04/19/08 03:52 PM
So, with the RSG front strut adapter.....Would you keep that?
Maybe I am overthinking the simple geometry here......The front strut would be the same then ---and the brake line prolly would be stretched only?
So in all it would be a 6" total front lift?
[Re: Hydra747]
#880251
04/19/08 05:38 PM
k i just want to make sure im understanding. you are asking if you could put a 2" spacer on top of the rsg front lift for a total of 6" of lift? what would you do for the back, areostar springs? i think that would be way cool if thats what you mean, but it may get awful tippy.
cone filter, boche platinum 4 plugs, 235/75/15 kumho all terrains jeep tj rear springs and rav 4 rear shocks, rocksport gear 4" front springs, warn manual hubs, 2.25 inch exhaust, no cat, 48" thrush glasspack
[Re: wyodriver4]
#880252
04/19/08 05:58 PM
The longer forks will do the same thing that my spacers do except on the other end, 4inches is still about the max lift you should go without lowering your front diff, the CV axles just cant take any more of an angle. Adding to the forks will cause problems so I would use the stock struts and springs. Daves Rocksport lift gives as much travel as shown on the pic on that website. Except for that 5.38 gears you can get the lifts here in the US from people you can get in touch with. It does look like quality stuff though.
Dennis
95 Sportage, gone but not forgotten. 98 Jeep TJ, 4" Zone springs with RC Long arms, Ford 8.8", 4.56 gears & Detroit locker rear, D30, 4.56 & Detroit Trutrack front.
[Re: Hydra747]
#880253
04/21/08 05:12 AM
in china they speak manadarin or cantonese /in korea they speak korean. One should also use proper "capital letters" where appropriate! <img src="/forums/images/graemlins/lol.gif" alt="" /> Thanks for the info on the language issue! <img src="/forums/images/graemlins/cheers.gif" alt="" /> I sent an E-mail and am awaiting a response......... Tried to call but did not get past the country code problem? <img src="/forums/images/graemlins/confused.gif" alt="" /> We will see what becomes of the e-mail aspect <img src="/forums/images/graemlins/sleeping.gif" alt="" /> iN cHINA tHEY sPEAK mANDARIN oR cANTONESE /iN kOREA tHEY sPEAK kOREAN. BeTtEr... <img src="/forums/images/graemlins/notooth.gif" alt="" />
[Re: sportagebandit]
#880254
04/21/08 02:36 PM
WISE GUY HERE? <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: Hydra747]
#880255
04/21/08 08:27 PM
hehe
btw the only company (overseas) that i have been able to get a hold of is automation king. which is the company in taiwan that makes a snorkel for the sportage.
