Re: just bought Pajero 2.5 int cooler turbo
[Re: asmTdi]
#880901
04/26/08 02:40 AM
what rpm should a stock 2.5 open its turbo? 2k or 2.5k? AFAIK it is running all the time... Good luck!
Fight for Right to drive from Right! www.ivoac.caStay away from Nic's Garage at 120 West 1st Ave in Vancouver BC!!!
[Re: spence121]
#880902
04/26/08 02:46 AM
Very good reading. Thanks a lot!
Good luck!
[Re: asmTdi]
#880903
04/28/08 12:07 AM
I've heard the 4M40 is not so reliable as 4D56 is. For what it's worth.... the local MMC dealer here (OZ) says the 4AM40 is more reliable - one reason being a timing chain rather than a belt.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
[Re: Bernoulli]
#880904
04/28/08 08:41 PM
I've heard the 4M40 is not so reliable as 4D56 is. For what it's worth.... the local MMC dealer here (OZ) says the 4AM40 is more reliable - one reason being a timing chain rather than a belt. i would agree...these timing belt days should have been long over especially with these SUVs that are put to such stressed driving conditions and are expected to be reliable. one minor belt can wreck havoc in the motor..
1993 Pajero Xp LWB 2.5TDiC
[Re: asmTdi]
#880905
04/29/08 02:15 AM
lurkin for info <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: asmTdi]
#880906
04/29/08 03:16 AM
What else I've heard when chain stretch out a little bit you'll hear character metal noise under the hood...
Good luck!
[Re: Pajerist]
#880907
04/29/08 05:36 AM
I had a toyota 4X4 with the 22r motor. It had 300+ K and the chain was fine.
1991 MITSUBISHI PAJERO EXCEED
[Re: DonM]
#880908
04/29/08 03:35 PM
Timing chain on the 4m4* engine is designed to last the lifetime of the engine (it's not a service item).
Failures are very rare and usually traceable to incorrect fitting or rotating the engine in the wrong direction (which is a NO-NO on those engines).
Don't ascribe to malice anything that can be adequately explained as stupidity! Pajero LWB Gen1 3.2 Di-D TD Engine 33" Bridgestone D694s 2" Lift Front Runner Rack
[Re: 4ePajero]
#880909
04/29/08 04:56 PM
timing chains are designed to last forver...aslong as you change your oil regularly they should never fail. this belt idea sure is stupid!
[Re: torquemonster]
#880910
04/29/08 11:00 PM
I can see the benefits to a belt system - quieter and lighter. If only they weren't such a PITA to change.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6384 MB (Peak: 0.7459 MB) Data Comp: Off Server Time: 2026-06-21 19:02:01 UTCValid HTML 5 and Valid CSS
