Page 3 of 4 1 2 3 4
Re: just bought Pajero 2.5 int cooler turbo [Re: asmTdi] #880901 04/26/08 02:40 AM
Pajerist Offline
what rpm should a stock 2.5 open its turbo? 2k or 2.5k?
AFAIK it is running all the time...
Good luck!
Fight for Right to drive from Right!
www.ivoac.ca
Stay away from Nic's Garage at 120 West 1st Ave in Vancouver BC!!!
Re: just bought Pajero 2.5 int cooler turbo [Re: spence121] #880902 04/26/08 02:46 AM
Pajerist Offline
Very good reading. Thanks a lot!
Good luck!
www.ivoac.ca
Re: just bought Pajero 2.5 int cooler turbo [Re: asmTdi] #880903 04/28/08 12:07 AM
Bernoulli Offline
I've heard the 4M40 is not so reliable as 4D56 is.
For what it's worth.... the local MMC dealer here (OZ) says the 4AM40 is more reliable - one reason being a timing chain rather than a belt.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: just bought Pajero 2.5 int cooler turbo [Re: Bernoulli] #880904 04/28/08 08:41 PM
asmTdi Offline OP
i would agree...these timing belt days should have been long over especially with these SUVs that are put to such stressed driving conditions and are expected to be reliable. one minor belt can wreck havoc in the motor..
1993 Pajero Xp LWB 2.5TDiC
Re: just bought Pajero 2.5 int cooler turbo [Re: asmTdi] #880905 04/29/08 02:15 AM
comp Offline
lurkin for info <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: just bought Pajero 2.5 int cooler turbo [Re: asmTdi] #880906 04/29/08 03:16 AM
Pajerist Offline
What else I've heard when chain stretch out a little bit you'll hear character metal noise under the hood...
Good luck!
www.ivoac.ca
Re: just bought Pajero 2.5 int cooler turbo [Re: Pajerist] #880907 04/29/08 05:36 AM
DonM Offline
I had a toyota 4X4 with the 22r motor. It had 300+ K and the chain was fine.
1991 MITSUBISHI PAJERO EXCEED
Re: just bought Pajero 2.5 int cooler turbo [Re: DonM] #880908 04/29/08 03:35 PM
4ePajero Offline
Timing chain on the 4m4* engine is designed to last the lifetime of the engine (it's not a service item).
Failures are very rare and usually traceable to incorrect fitting or rotating the engine in the wrong direction (which is a NO-NO on those engines).
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
Re: just bought Pajero 2.5 int cooler turbo [Re: 4ePajero] #880909 04/29/08 04:56 PM
torquemonster Offline
timing chains are designed to last forver...aslong as you change your oil regularly they should never fail. this belt idea sure is stupid!
Re: just bought Pajero 2.5 int cooler turbo [Re: torquemonster] #880910 04/29/08 11:00 PM
redbull Offline
I can see the benefits to a belt system - quieter and lighter. If only they weren't such a PITA to change.
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6381 MB (Peak: 0.7618 MB) Data Comp: Off Server Time: 2026-06-13 16:02:45 UTC
