Spring over axle #881727 04/19/08 04:29 PM
tomcasino Offline OP
I'm in the process of restoring a 1981 CJ 5. I did a spring over axle swap and I have a problem with the tie rod from the pitman arm hitting the leaf spring when turning to the right. Will I need a high steer kit? I'm using 2 1/2" Skyjacker springs with a dropped pitman arm and a Dana 30 front axle. I know someone has run into this problem. I'm just wondering what their solution was. Any help would be greatly appreciated.
Re: Spring over axle [Re: tomcasino] #881728 04/23/08 02:56 PM
superdawg Offline
Many a book has been written on this subject...
Wait, ooops, many a post..
a) SOA is cake,
b) Drivelines working correctly at full suspension travel, harder.
c) Steering...is where the folks charging good money at professional 4x4 shops earn theirs.
"c" is what I do.
Bending the drag link to make it work, is what I throw away.
A bend in a steering link asks for it to bend more on the trail. a gusseted bent link just prolongs the further bending.
D44 flat top knuckles, upgrading brakes from CJ to GM or Wag, using GM spindles, Ford Hubs...GM Knuckles. then do Cross over steering (minimum) or double high steer with steering links mounted to high steer arms.
SD
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5861 MB (Peak: 0.6340 MB) Data Comp: Off Server Time: 2026-06-23 00:00:46 UTC
