turbo ecu wiring question #881768 04/19/08 09:51 PM
W
whitelespaul Offline OP
For the starter switched power connections, #2 and #11, Should they be Start only or Start and On powered?
What size fuse for the direct battery connections for the ecu and fuel pump relay?
83 mitsu flat bed 2.6l weber, 88 auto tranny, 2" body lift, 4.625 LSD, 235/85-16E mudders (33 x 9.50).
Re: turbo ecu wiring question [Re: whitelespaul] #881769 04/21/08 06:24 PM
start only.
Use the fuse size from a starquest multipurpose fuse. I'd start with a 10a, and if it blew, try a 15a.
Re: turbo ecu wiring question [Re: fasteddy] #881770 04/22/08 01:15 AM
87Raider_TSI Offline
The ECU and ignition circuits use fuseable links. A Red link rated at between 9-17A max and a Brown rated at 5A max.
Fuseable links work pretty well and are still available from the dealer or Enginemachineservice.com.
If your going with the blade style fuses I think fasteddy's advice is pretty good. You really shouldn't need anything higher than a 10A fuse. If you popping 10A fuses easily you may want to re-check your wiring.
'87 Raider SWB 2.6T/5 spd - Boxy and boosted.
'88 Conquest TSI - MPI and lots of other mods
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5903 MB (Peak: 0.6434 MB) Data Comp: Off Server Time: 2026-06-25 00:59:53 UTC
