Page 5 of 7 1 2 3 4 5 6 7
Re: Project Resurrection [Re: PA_JERO] #882077 04/27/08 06:05 AM
52degrees Offline
My wife took one look and said, "that's the special bus."
KG6VNX
Re: Project Resurrection [Re: 52degrees] #882078 04/27/08 12:47 PM
Happy Birthday hazy_daze Offline
Word.
To your mother.
G.
Dizzle.
Re: Project Resurrection [Re: hazy_daze] #882079 04/28/08 05:35 AM
W
warrior Offline
What is the 2.4 out of?
Re: Project Resurrection [Re: warrior] #882080 04/28/08 08:31 AM
TOASTY Offline OP
ours came from a '94 mitsu pickup but you can bolt on any RWD 2.4l out of mighty max, RAM 50, or Montero sport. This swap is a bolt on for 2.6 powered monty the only thing is some engines have different crank bolt patterns so you will need the flexplate that goes to the engine
Re: Project Resurrection [Re: TOASTY] #882081 04/28/08 07:12 PM
W
warrior Offline
Thanks for the info. Do you know if the clutch setup from the 2.6 will work on the 2.4?
Re: Project Resurrection [Re: warrior] #882082 05/04/08 05:53 PM
PA_JERO Offline
I'm not sure if the clutch will swap. I do know that the 2.4 flywheel is a 7 bolt where as the 2.6 is a 6 bolt. You might have to go compare the two at a junkyard, I'm not to sure on all the differences.
well, today we will be trying to progress a little bit more on this swap, so we'll keep you posted
Re: Project Resurrection [Re: PA_JERO] #882083 05/04/08 11:51 PM
lordtrunks Offline
early 2.4s are 6 bolt
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Project Resurrection [Re: StockRaider] #882084 05/05/08 04:28 AM
87Montero Offline
goddamn you guys... you got me wanting to chop top a SWB... hmmm Brendan? <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Do it up!
Re: Project Resurrection [Re: 87Montero] #882085 05/05/08 09:16 PM
PA_JERO Offline
chop tops are pretty cool, they are definetly a awesome look to a swb montero. If your gonna do one I suggest a soft top be made to be put back on for certain whether conditions, cause I know out here in AZ there is alot of people that probably wouldn't be able to handle the 117 degree days out here with out a top on
Re: Project Resurrection [Re: PA_JERO] #882086 05/06/08 09:05 AM
TOASTY Offline OP
we made progress on the project this sunday, we got the engine
in place and the new mounts tack welded on. Now we just need a heavier duty welding machine to weld it in permanantly.
PHP: 7.4.33 Page Time: 5.988s Queries: 16 (0.006s) Memory: 0.6429 MB (Peak: 0.7506 MB) Data Comp: Off Server Time: 2026-06-23 18:42:22 UTC
