Re: Project Resurrection
[Re: PA_JERO]
#882077
04/27/08 06:05 AM
My wife took one look and said, "that's the special bus."
KG6VNX
[Re: 52degrees]
#882078
04/27/08 12:47 PM
Word.
To your mother.
G.
Dizzle.
[Re: hazy_daze]
#882079
04/28/08 05:35 AM
[Re: warrior]
#882080
04/28/08 08:31 AM
ours came from a '94 mitsu pickup but you can bolt on any RWD 2.4l out of mighty max, RAM 50, or Montero sport. This swap is a bolt on for 2.6 powered monty the only thing is some engines have different crank bolt patterns so you will need the flexplate that goes to the engine
[Re: TOASTY]
#882081
04/28/08 07:12 PM
Thanks for the info. Do you know if the clutch setup from the 2.6 will work on the 2.4?
[Re: warrior]
#882082
05/04/08 05:53 PM
I'm not sure if the clutch will swap. I do know that the 2.4 flywheel is a 7 bolt where as the 2.6 is a 6 bolt. You might have to go compare the two at a junkyard, I'm not to sure on all the differences.
well, today we will be trying to progress a little bit more on this swap, so we'll keep you posted
[Re: PA_JERO]
#882083
05/04/08 11:51 PM
89 2 dr turbo diesel 89/88 "Backwoods sas"
[Re: StockRaider]
#882084
05/05/08 04:28 AM
goddamn you guys... you got me wanting to chop top a SWB... hmmm Brendan? <img src="/forums/images/graemlins/cyclops.gif" alt="" /> Do it up!
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: 87Montero]
#882085
05/05/08 09:16 PM
chop tops are pretty cool, they are definetly a awesome look to a swb montero. If your gonna do one I suggest a soft top be made to be put back on for certain whether conditions, cause I know out here in AZ there is alot of people that probably wouldn't be able to handle the 117 degree days out here with out a top on
[Re: PA_JERO]
#882086
05/06/08 09:05 AM
we made progress on the project this sunday, we got the engine in place and the new mounts tack welded on. Now we just need a heavier duty welding machine to weld it in permanantly.
