Milage Help #882603 04/25/08 01:44 AM
slowhand74 Offline OP
What can I do to improve the gas milage on my 2000 Tacoma? It's a 3.4 auto. Any Ideas will help. Thank ahead of time.It gets 16mpg highway.
Re: Milage Help [Re: slowhand74] #882604 04/25/08 04:36 AM
Mark in AZ Offline
Toyota Moderator
Remove any extra weight
Increase air pressure in tires
Replace air filter
Clean MAF (there's a how to article on this site)
Things you might have to pay someone to do
Replace spark plugs
Clean fuel injectors
Switch to synthetic lubricants
Try one at a time, monitor, try the next.
I get about 12.5 mpg on 37" tires and 3 miles to work, several more on the highway up to about 65 mph.
Exploring in a T4R Ltd V8
Re: Milage Help [Re: slowhand74] #882605 04/25/08 09:29 PM
BIGBURLYNAKEDMAN Offline
Mark put it perfectly. I would recommend all the same things, in that order. Do one, then wait, then do another.
Air pressure is a mileage killer. I usually keep anywhere between 28-32 psi in the rear (without heavy loads) and 36 psi up front.
I'm supercharged and getting 18.6 on highway and about 16.7 - 17 in the city, so there's no way you should be getting 16 highway unless you drive like a maniac! <img src="/forums/images/graemlins/drunk.gif" alt="" />
'99 Tacoma Xtra cab V6 TRD
TRD Supercharged, URD 7th injector and 2.2" pulley, 32X11.5 BFG All-Terrains, OME 881 3-inch lift/Toytec AAL, 5100 Series Bilsteins all around, and ProComp 130 lights.
No I'm not some creepy naked guy...
Re: Milage Help [Re: slowhand74] #882606 04/25/08 09:56 PM
humanoid Offline
Invest in a ScanGaugeII, it has a real-time MPG readout as well as other functions. It'll change your driving habits for sure, it did mine.
scangauge.com
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5998 MB (Peak: 0.6558 MB) Data Comp: Off Server Time: 2026-11-02 14:05:21 UTC
