Page 2 of 3 1 2 3
Re: Car Talk puzzler for lifted truck [Re: DirtDriver] #882754 04/26/08 06:13 PM
CapnCrunch Offline
Haven't seen this one yet:
Flip the truck on its side and drag it out. <img src="/forums/images/graemlins/shiner.gif" alt="" />
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Car Talk puzzler for lifted truck [Re: CapnCrunch] #882755 04/26/08 06:39 PM
FrankR Offline
Assuming the tires were oversized - necessitating the 2" lift.... and airing down would make the tires bulge too much to clear the door width, the only sensible thing to do would be to unwind the front torsion bars and install compressors on the rear springs.
Or, if that's too much work, you could install a set of standard tires, drive out and swap tires again.
Or, if you wanted to save some money on the second set of tires, you could put a jack under both differentials, remove all wheels/tires, lower both jacks..... and roll the truck out on the jacks.
Frank
Re: Car Talk puzzler for lifted truck [Re: FrankR] #882756 04/26/08 06:41 PM
52degrees Offline
I think he has one of those uber wide 2-car garage doors.
KG6VNX
Re: Car Talk puzzler for lifted truck [Re: 52degrees] #882757 04/26/08 06:59 PM
sparkem Offline
Or remove body from the truck. Roll out the chassis. Carry out the body. Then bolt the body back on.
Re: Car Talk puzzler for lifted truck [Re: sparkem] #882758 04/26/08 08:41 PM
CapnCrunch Offline
Spend next several years acquiring grants, looking for investors, hiring scientists, doing research, gaining political capital, giving lectures, doing more research, and eventually manufacturing a teleportation device to instantly break down the truck at the sub-atomic level, transporting it outside, and reconstituting it in the driveway.
Or you could just climb in behind the wheel, start the engine, put it in gear, and go for broke.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Car Talk puzzler for lifted truck [Re: CapnCrunch] #882759 04/26/08 09:43 PM
DirtDriver Offline OP
Freakin' hilarious suggestions guys, thanks. Would have been more enjoyable if I hadn't snorted diet Pepsi out my nose while reading them.
Kudos to the Capn for getting it in 26 minutes.
Turns out his last suggestion was the best. Apparently my garage floor has an unnoticable slope--I can actually get out fully aired with about 1/16 clearance.
Capn, your imaginary prizes are on their way to you in your imaginary teleporter. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Re: Car Talk puzzler for lifted truck [Re: DirtDriver] #882760 04/26/08 09:46 PM
CapnCrunch Offline
Can I get second set for my imaginary friend? <img src="/forums/images/graemlins/cyclops.gif" alt="" />
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Car Talk puzzler for lifted truck [Re: CapnCrunch] #882761 04/26/08 10:33 PM
MarkG Offline
Cut a new door out the backside of the garage. Then go wheeling in the back yard. Drive out thru your neighbors yard to the street.
Re: Car Talk puzzler for lifted truck [Re: DirtDriver] #882762 04/26/08 11:25 PM
FrankR Offline
No fair at all..... we assumed this to be true:
Enough that I couldn't drive it out!
So were you lying then.... or are you lying now? Or did you actually believe your lying eyes? Either way, we can't solve a puzzle based on false premises. <img src="/forums/images/graemlins/shame.gif" alt="" />
Some professor you'd make. <img src="/forums/images/graemlins/lol.gif" alt="" />
Frank <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Car Talk puzzler for lifted truck [Re: FrankR] #882763 04/26/08 11:59 PM
Line rear of truck with new tarp (no holy tarps) and fill with water. Use board across console gap in front seats. Pray for front seat back latches...
Remove trim board under garage header.
Enlist all friends over 200lbs (I got 7 on there for long enough) to stand on front bumper.
Air down and scrub out the single garage door, leaving only minor rubber burns on the side frames of the door, and the door roller tracks almost still straight.
Don't ask how I know...
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6422 MB (Peak: 0.7509 MB) Data Comp: Off Server Time: 2026-06-10 00:07:19 UTC
