help me figure out whats wrong with 87 raider
#883090
04/28/08 06:58 AM
so she has sitten for 2 years after putting a new transmisson in and finally getting a temp gauge
she runs hot i don't know why i have changed thermo flushed raidiator all that jazz shes running hot
the transmisson has like 10 miles on it and it still grinds and i have to ride the clutch the whole time i dont know what could be wrong my dash lights won't turn off period so yeah i dunno what to do
Re: help me figure out whats wrong with 87 raider
[Re: blackmage]
#883091
04/28/08 01:26 PM
Seems you have a couple of different problems and you'll want to tackle them separately.
First, for the transmission, make sure it has the proper type and amount of fluid in it. The wrong oil can cause grinding. The FSM calls for Hypoid gear oil GL-4 or higher, 80w or 75w-85w. Use a quality oil...I've heard the redline gear oil helps with synchro clash. Also, you mention some troubles with the clutch. It's a hydraulic clutch and if it's not working properly may also cause grinding. Make sure the clutch master cylinder has the proper amount of brake fluid in the reservoir. You may need to have the system bled or possibly need a new slave cylinder or something. With the engine idling, can you depress the clutch and move through the gears without it grinding while sitting still?
The 2.6L doesn't like to run hot so best to nip this one in the bud right away. I'd probably start with having the radiator checked by a radiator shop. Maybe they can boil and/or rod the radiator. Make sure the radiator cap is in good condition (the pressure it creates in the system raises the boiling temp) and that you have a good 50/50 mix of anti-freeze/water. When was the water pump last replaced? How about the fan clutch? All of these things can affect how hot or cool the engine runs. One last thing, the thermostat on these engines have a bleed hole in them and they have to point in a certain direction when installed. This helps bleed trapped air out of the system (and trapped air will also make it run hot). I always fill the system slowly and run it with the cap off until the thermostat is wide open and coolant is circulating before topping it all the way off and installing the cap.
The dash lights problem will be a little trickier to track down. It may be as simple as replacing the headlight switch or a relay has gone bad. According to the FSM, the lighting relay is located under the hood, right behind the drivers headlight. Try just unplugging it and see if the dash lights turn off. By the same token, you can unplug the light switch and see if that powers off the relay. One or the other is holding the dash (and I assume the exterior running lights) on.
Hopefully that will get you started on getting her back on the road. Good luck! <img src="/forums/images/graemlins/cheers.gif" alt="" />
-Todd 1987 Montero 2.6l 5-speed (Sold...but I still miss her) 2008 Jeep Patriot Sport 4x4
[Re: blackmage]
#883092
04/28/08 01:30 PM
Clutch fan could be bad. So it is not cooling.
Is it a used tranny? Did you put in a new clutch disk? How is the clutch master cylinder?
Why do you have to ride the clutch?
Well on my way to becoming that eccentric old man in every town.(crazy as a s#@thouse rat) With a yard full of desireable old vehicles that tells you, Sorry they're not for sale..... Someday I'm going to fix them.
[Re: highmtndesert]
#883093
04/28/08 07:12 PM
i honestly don't know when the water pump was last replaced how hard what would the labor cost i live in colorado any mitsi guys who wanna help me?
the fan clutch could be one of the reasons why its getting hot that looks like something i could figure out then again i never worked on my own car don't know what the anything is i apologize for my grammar and punciation i never went to English class ever.
when i bought here the transmission bell housing was cracked i paid 1000 for a replacement out of Houston came with a year warranty i doubt they put the right transmission fluid in there i know i need some sort of pump to put some in. I found a master cylinder in a white box looked in good condition i haven't seen the one thats in no i didn't replace the clutch and haven't had it bled yet i will look up the parts i just need someone in Colorado who would wanna do labor or help me out ifi can't get it my self?
[Re: blackmage]
#883094
04/28/08 07:28 PM
Where at in CO are you? Denver area? I am down in the Springs area but I do come up to Saudi Aurora and Parker area quite alot. If I can give you a hand with something let me know.
Z
Do you think the average stormtrooper knows how to install a toilet main? All they know is killing and white uniforms.
87 Raider TSI 84 K5, 350/700R4,36" TSLs, spooled fr/rr 74 VW Bug- volksrod project 68 VW Fastback, 2L T4 powered
[Re: CwnAnwyn]
#883095
04/29/08 03:11 AM
i live in commerce city so found out it had like no coolant fixed that don't run hot or make any smells now
it makes a grinding sound when i take the foot off the gas like a schhooowwwwww noise theres a little rattle that sounds like somethings spining to comeing form underneath
[Re: blackmage]
#883096
04/29/08 05:30 AM
Did you adjust the linkage after installing a new clutch set? Or did you replace it?
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
