adding a little more lift to the front and rear #883230 04/29/08 04:53 AM
sportagebandit Offline OP
i know you guys have told me 4 inches up front is the max on the ifs. <img src="/forums/images/graemlins/scared.gif" alt="" /> but i still want another inch or so up front and 1.5 to 2 out back. <img src="/forums/images/graemlins/nana.gif" alt="" /> i am currently making 1/2" spacers for the front to add to my 3/4" up yor kia spacers and eibach spring. in the rear i gotta 2" spacer with the eibach springs which i am ditching the eibach spring and keeping the spacer and installing tj 105aa springs...
will let you guys know how it comes out...
96 SPORTAGE 4 DOOR:1 3/8 body lift:eibach springs & spacers:15x8 rockcrawlers & 31x11.50 super swampers:warn hubs:winch bumper http://www.cardomain.com/ride/2115301
Re: adding a little more lift to the front and rear [Re: sportagebandit] #883231 04/29/08 05:45 AM
DEFBOY35 Offline
will 1/4" spacer give you an extra inch up front?
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: adding a little more lift to the front and rear [Re: sportagebandit] #883232 04/29/08 01:26 PM
Dave Scott Offline
the most you can space the strut down in front is 1.125" or the bottom of the strut will smack right into the CV joints on the front axle and tear the crap outta the boot. in the rear, you need to be careful that the coils aren't too curved or they will wear out really fast and provide a bad ride on the road. also, you need to watch the relationship between the upper link and your pinion as well as the lower coil buckets and the axle centering (panhard rod length).
Re: adding a little more lift to the front and rear [Re: Dave Scott] #883233 04/29/08 07:05 PM
fokion Offline
additionaly the joint at the upper A arm will have an extreeeeeeme angle and your downward travel will be nearly zero..
Re: adding a little more lift to the front and rear [Re: fokion] #883234 04/29/08 09:21 PM
Everet Offline
Only other way to get more lift is to go with a 3" body lift. The kit is available but it may be difficult to make shifters work correctly. Otherwise, SAS is the answer.
Everet
Re: adding a little more lift to the front and rear [Re: Dave Scott] #883235 04/30/08 12:03 AM
so i shouldn't add more than 3/8" to the already existing lift.
i will have the machine shop shave off .125" of the 1/2" spacer.
Re: adding a little more lift to the front and rear [Re: sportagebandit] #883236 04/30/08 03:35 AM
DennisThompson Offline
I did some experimenting (trial and error) when I started making the spacers and with the Eibachs the 3/4" spacers is the tallest I got to work without the cv axles not rubbing on the strut forks. If you want more lift think about a body lift or a SAS.
Dennis
Re: adding a little more lift to the front and rear [Re: DennisThompson] #883237 04/30/08 02:46 PM
Dave Scott Offline
Dennis
i think you're right, i think they rub a little even with my kit when the upper ball joint starts to wear a little from being allowed to over extend slightly.
Re: adding a little more lift to the front and rear [Re: Dave Scott] #883238 05/07/08 05:51 AM
ok i got the spacers back from the machinist, and then gave em back to him and to him remove some material. instead of .500" spacers they are now .300".
PHP: 7.4.33 Page Time: 1.258s Queries: 15 (0.004s) Memory: 0.6281 MB (Peak: 0.7318 MB) Data Comp: Off Server Time: 2026-06-19 02:52:45 UTC
