Removing the Dash, need some help #883588 04/30/08 11:09 PM
Jon94JGC Offline OP
I have the vehicle stripped of interior for Herculiner, and I thought I'd pull the dash to clean out the vents, but it's giving me trouble. I removed the 12mm side bolts and the 12mm nut behind the center gauges, but it's still stuck, can anyone help?
I'm taking pics along the way so maybe I can help someone else at a later date.
1989 Raider 3.0 5 speed 225K Possible rebuild about 30k ago, no proof.
Dual Bouncy seats, HL washers. New Mud King 235's on 15x7 Crager soft 8's. Dark tint. Superwinch hubs. Herculined Interior.
Re: Removing the Dash, need some help [Re: Jon94JGC] #883589 05/01/08 02:12 AM
DirtDriver Offline
Download the 89 manual from www.mitsubishilinks.com and see if you got all the mounting bolts.
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Re: Removing the Dash, need some help [Re: DirtDriver] #883590 05/01/08 02:30 AM
CapnCrunch Offline
You'll need to look at the BODY sub-section (23), starting at page 72.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: Removing the Dash, need some help [Re: CapnCrunch] #883591 05/01/08 03:18 AM
Jon94JGC Offline OP
Thanks guys, I found the last two bolt/nuts. You have to pry up the side window defroster vents, there are nuts behind them. Now that my dash is out, should I throw in a heater core, or anything while I'm in there?
Re: Removing the Dash, need some help [Re: Jon94JGC] #883592 05/01/08 03:31 AM
hazy_daze Offline
Not a bad idea, indeed.
Re: Removing the Dash, need some help [Re: hazy_daze] #883593 05/01/08 04:15 AM
Jon94JGC Offline OP
Here is where I got to today;
[Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image]
Re: Removing the Dash, need some help [Re: Jon94JGC] #883594 05/02/08 05:37 AM
DirtDriver Offline
Well done, m8! Those vents really needed a good cleaning!
The heater core might be worth a look, but do you want to spend the ~$300 for a new one? Since you know how easy it is to remove the dash now, you can always replace it if you had to. <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: Removing the Dash, need some help [Re: DirtDriver] #883595 05/03/08 02:45 AM
Jon94JGC Offline OP
I agree, I looked at it while I was in there and it looked fine (like I would know what a bad one looked like)
now that I know how to remove the dash, it will be no big deal if the heater motor, or evap core, or anything else goes bad.
Re: Removing the Dash, need some help [Re: Jon94JGC] #883596 05/03/08 02:57 AM
IMHO removal is usually easier than replacement/reassembly. <img src="/forums/images/graemlins/lol.gif" alt="" />
JK... sort of anyway.
Glad to see you got it apart w/out issues. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Removing the Dash, need some help [Re: Jon94JGC] #883597 05/03/08 07:30 AM
Oyaji_Jon Offline
Since you have it apart, can you tell me if there looks to be enough room for a vertical tube (for a cage) to penetrate the dash and go to the floor? I'm curious if there's any sheet metal/ducting that will prevent this in the left and right corners by the windshield frame.
Thanks in advance for any assistance you can give.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6403 MB (Peak: 0.7652 MB) Data Comp: Off Server Time: 2026-06-24 15:59:50 UTC
