Aftermarket wheels, what size fits, what back spacing #883746 05/01/08 04:36 PM
Jon94JGC Offline OP
I just re-read the faq and only find tire stuff, I did see that the factory wheels are 6" wide. What is the back spacing, and what back spacing works well, I'm only running 30x9.50's. I like Crager soft 8's, and I think their standard bs is 4".
1989 Raider 3.0 5 speed 225K Possible rebuild about 30k ago, no proof.
Dual Bouncy seats, HL washers. New Mud King 235's on 15x7 Crager soft 8's. Dark tint. Superwinch hubs. Herculined Interior.
Re: Aftermarket wheels, what size fits, what back spacing [Re: Jon94JGC] #883747 05/01/08 06:22 PM
don Offline
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: Aftermarket wheels, what size fits, what back spacing [Re: Jon94JGC] #883748 05/01/08 06:22 PM
reknawj Offline
I'm in the same boat as you, here is a bit more info.
stock alloy's (at least on a '94 SR) 15 x 7 +12mm offset
lug pattern - 6 lugs x 5.5" or 6 x 139.7mm
Maybe someone can chime in on the hub centric/lug centric thing. I'm pretty sure these are hub centric vehicles, but can you put lug centric wheels on? (I'm hijacking your thread but it's the same topic!)I already know GM and toyota has the same pattern.
I found some used tacoma steelies for 40 bucks each, if they have the right offset I can put those on I hope.
Oh, back to the Cragars, I'm pretty sure the B.S. of 4" (zero offset right?) makes them a perfect fit but pretty sure doesn't really cut it.
1994 Montero SR
Divide Colorado
Re: Aftermarket wheels, what size fits, what back spacing [Re: Jon94JGC] #883749 05/01/08 06:24 PM
Stock wheels for the Gen I is 15" x 6" with 4" backspace, either steel or alloy. If you're not going to run larger tires, you could just paint your wheels shiny black. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Some guys are using the stock wheels with 33x10.5's AT/MT or 32x9.5 Swampers.
I'm running some aftermarket alloys, 15 x 8 with 4" BS, 33x12.5 muds with no rubbing issue. I've trimmed the front bumper ends and splash gaurds at the front edge of the front wheel wells already.
The Gen I wheels are not hub-centric.
Re: Aftermarket wheels, what size fits, what back spacing [Re: rxinhed] #883750 05/01/08 07:22 PM
don Offline
My 87 came with 15x6 rims, 4.375" BS
I changed to 31x10.5's on 15x7's, 3.75" BS
then to 33x12.5's on 15x8's, 3.25" BS
No rubbing on suspension, but bumper plastic end cap needed trimming.
I'm looking at a set of 295/75 R16's (~33.5x11.5) on 16x8's, 4.25" BS to use as hiway tires (to give the 33x12.5's a rest on long high speed runs), and I'm really hoping they have no issues. The inner tire edge will line up with the original tire's inner edge, so it will be close on tight turns.
Hub-centric is of no use to you, as the center hole will be too small to fit the older Mitsu/Toy/etc hubs that we have in Gen1's.
Re: Aftermarket wheels, what size fits, what back spacing [Re: don] #883751 05/01/08 09:09 PM
Here is a rear view of the 33x12.5s on 8s:
Here is a flexed view of 33x12.5s on 10s in the back, 4" BS:
Here is a view of 32x11.5s on stock rims, flexed...tire hits rear of frame:
I have other views, too, but these show the limits I've found for my truck. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Aftermarket wheels, what size fits, what back spacing [Re: rxinhed] #883752 05/02/08 10:54 PM
FatTony Offline
I have 33X12.5's on 15X10 Rims, with a 4" backspacing. They rub on the fenders both front and rear when flexing or hitting bumps while turning. No rubbing on frame or suspension components though. Stick out a lot past the fenders, ~4-5" on the front, ~3" on the back. I think if I put my sway bar back on they wouldn't rub, but sway bars are for men who wear panties. <img src="/forums/images/graemlins/ignore.gif" alt="" />
88 Raider sas, doubler, boggers
Re: Aftermarket wheels, what size fits, what back spacing [Re: FatTony] #883753 05/02/08 11:30 PM
So whatch'ya sayin'? <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" />
I like my Gen I 4-door sway bar, helps a bunch in the tight corners. <img src="/forums/images/graemlins/pfft.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Aftermarket wheels, what size fits, what back spacing [Re: rxinhed] #883754 05/03/08 01:46 PM
Happy Birthday hazy_daze Offline
I like my Gen I 4-ddor sway bar, helps a bunch in the tight corners. <img src="/forums/images/graemlins/pfft.gif" alt="" />
Tony, couldn't agree more. I love how mine rides and handles without the sway bars.
Russell, do you prefer the thong type or the more supportive granny panty <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: Aftermarket wheels, what size fits, what back spacing [Re: hazy_daze] #883755 05/03/08 02:54 PM
Oyaji_Jon Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6428 MB (Peak: 0.7693 MB) Data Comp: Off Server Time: 2026-06-23 13:38:27 UTC
