Alignment after UCA swap #883934 05/03/08 01:10 AM
DirtDriver Offline OP
I got an alignment after installing the Gen2 UCA's. My before toe measurements were way off. Spec is 0.08-0.36 degrees. Left was negative 2.07; right was positive 2.56. I wonder if changing the UCA's was the cause? I'm surprised they were so far off, because the truck was tracking fine before the alignment. I could take my hands off the steering wheel and it would keep going straight as an arrow.
The only unresolved issue is right camber. Range is 0.5-1.5 degrees, and I'm at 0.2. So I need to increase camber by 0.8 to get it in the middle of the range. Using a handy-dandy degrees/minutes calculator on the web, 0.8 converts to 48 minutes of adjustment. The FSM says a 1mm shim will provide 13 minutes of adjustment, so I'm about two 2mm shims off, right?
The FSM isn't really clear, but I think I need to add shims to increase camber, correct?
That would put me at 4 2mm shims on that side. Is it OK to have that many shims?
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Re: Alignment after UCA swap [Re: DirtDriver] #883935 05/03/08 12:00 PM
FrankR Offline
With 33" tires, you should set camber on both sides at 0*.... or as close as you can get to 0*..... your tires will last longer and handling will improve.
Frank
Re: Alignment after UCA swap [Re: FrankR] #883936 05/03/08 03:45 PM
powerRam50 Offline
ya you are better to be closer to 0 with larger tires as said.
Re: Alignment after UCA swap [Re: powerRam50] #883937 05/03/08 07:03 PM
hazy_daze Offline
I set mine to 0* camber and it feels great, with even wear on the tires.
Re: Alignment after UCA swap [Re: FrankR] #883938 05/03/08 09:32 PM
Ok, so I should go for 0* camber. But I'm still confused on the effect of adding or removing shims. If I remove a shim, then the UCA shaft is closer to the frame, and the ball joint is farther out from the frame. Then the top of the knuckle is out farther, tilting the wheel out at the top, increasing camber. So the rule is remove shims to increase camber, and add shims to decrease camber. Do I have that right?
Re: Alignment after UCA swap [Re: DirtDriver] #883939 05/03/08 11:00 PM
FrankR Offline
Yes. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Also, set your passenger side caster about 0.5* more positive than the driver side.
Frank
Re: Alignment after UCA swap [Re: FrankR] #883940 05/03/08 11:56 PM
How cum?? road camber? driver tilt effect? engine torque?
Re: Alignment after UCA swap [Re: fasteddy] #883941 05/04/08 12:48 AM
FrankR Offline
Road camber.
If the caster is different from side to side, the vehicle will pull to the side with the less positive caster. If the caster is equal but too negative, the steering will be light and the vehicle will wander and be difficult to keep in a straight line. If the caster is equal but too positive, the steering will be heavy and the steering wheel may kick when you hit a bump.
web page
Driver weight should be allowed for by cranking the driver side torsion bar until the driver side bumper corner is .25" higher than the passenger side with no one in the vehicle.
Engine torque on a stock 3.0L Gen1 is countered by opening a wing vent. <img src="/forums/images/graemlins/wink.gif" alt="" />
Frank
Re: Alignment after UCA swap [Re: FrankR] #883942 05/04/08 04:16 PM
justice Offline
It may be too late for this but from what others have said and from what I remember of looking at the set In my garage, the mounting shaft on the gen 2 arms, can be rotated 180 degrees. The thought being that the other side is a little bit thicker from the center axis making it easier to get the proper camber without the need for adding as many shimms. Maybe Tag or captn' can chime in on this one.
Re: Alignment after UCA swap [Re: justice] #883943 05/04/08 05:08 PM
Tag Offline
Sorry. I dont recall. I installed mine then took it to a shop for alignment.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6427 MB (Peak: 0.7674 MB) Data Comp: Off Server Time: 2026-06-12 11:55:59 UTC
