Starter Problem? #884031 05/03/08 12:22 PM
PatrickS Offline OP
New starting problem.
Battery is new but when I try and start the engine the starter turns very slow like the battery is almost dead. My wife is not thrilled with the idea of pushing me to start the motor. Is this the starter or could it be something else?
89 3.0 LWB Montero, 1st Gen, 5 Speed Manual, 5 Door
Re: Starter Problem? [Re: PatrickS] #884032 05/03/08 03:09 PM
FrankR Offline
Check the voltage across the battery terminals. If the battery has been installed for a few days and the engine has been running for a few hours, the battery should be fully charged and should show at least 12.5v. If not, remove, inspect, clean and tighten all battery connections, including the engine and frame grounds and the starter connections. If any cables show corrosion or frayed wires, replace them. Pay particular attention to the ground wire that connects to the inner fender on the passenger side.
If the wiring is ok, but battery voltage is low, the alternator is likely bad..... you can have it tested at most auto parts stores.
If the wiring and battery voltage are ok, the problem is likely in the starter motor.
Frank
Re: Starter Problem? [Re: FrankR] #884033 05/03/08 11:02 PM
mxmikie Offline
sounds like the starter brushes are gone
Re: Starter Problem? [Re: mxmikie] #884034 05/04/08 07:25 AM
93montero_sr Offline
You mean bushings <img src="/forums/images/graemlins/kewl.gif" alt="" />.Check the the battery with a meter running it should be around 14volts charging then turn the car off it should be around 12.5, if it just keeps droping then battery is no good if its not charging higher then 12 volts when running then the alternator is probaly on its way out. Then again its possible you bought a defective starter.
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: Starter Problem? [Re: 93montero_sr] #884035 05/04/08 07:16 PM
hazy_daze Offline
A starter has both. Follow Frank's advice in order.
PHP: 7.4.33 Page Time: 2.845s Queries: 15 (0.005s) Memory: 0.6075 MB (Peak: 0.6726 MB) Data Comp: Off Server Time: 2026-11-15 10:32:38 UTC
