fuel mixture screw? #884474 05/07/08 06:51 AM
W
wytee Offline OP
i have an 88 pickup 4x4 with the 22re. its efi. how do i set the fuel mixture correctly? oh and can i seperate the trans from the tranny without dropping them both?
"IM THERE BUDDY"
Re: fuel mixture screw? [Re: wytee] #884475 05/07/08 03:07 PM
OOP'S Offline
If you mean T-case from tranny, yes as long as it is a stick shift. Some of the automatic trannys, no.
Support engine
Remove shifter
Disconnect all wires and cables to T-case
Remove X-member
Remove bolts holding T-case to Tranny
Remove T-case
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: fuel mixture screw? [Re: wytee] #884476 05/07/08 03:21 PM
4Crawler Offline
With properly functioning ECU and sensors like the engine coolant temp. sender, the throttle position sensor, the air flow meter and the O2 sensor to name the big ones, then it is all automatic. For how it all works, see the Technical Articles at:
- http://www.autoshop101.com/
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5936 MB (Peak: 0.6469 MB) Data Comp: Off Server Time: 2026-06-20 00:30:46 UTC
