Page 4 of 4 1 2 3 4
Re: I did what everyone said and still have high idle when cold [Re: Jon94JGC] #885869 05/21/08 02:55 AM
G
generation_one Offline
the one you had was pointy metal pintle (the tip that fits inside the throttle body) and the junkyard one was plasic pintle?
what was the slight difference?
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: I did what everyone said and still have high idle when cold [Re: generation_one] #885870 05/21/08 03:02 AM
G
If so, then you found a problem.
As far as I know, only the pointy metal pintle will work, You have to take the electricals off the good one(plastic) and put them on the original (pointy metal).
about 200k miles
Re: I did what everyone said and still have high idle when cold [Re: generation_one] #885871 05/21/08 03:04 AM
G
it aint hard to do.
comes apart in two pieces
about 200k miles
Re: I did what everyone said and still have high idle when cold [Re: generation_one] #885872 05/21/08 03:37 PM
8
89IsMine Offline
it aint hard to do.
True, but I think the big problem was the JY one had a blown coil as well.
When I tested the ohms on the 'new' one it was way different than mine. Don't know what that means, I do know that the 'new' one came out of a different year than mine (don't remember what year though)
The resistance on the 'new' 1-2=76 2-3=34 1-3=105
The second row seems normal 4-5=33 5-6=33 4-6=62
Looks like the 1-2 coil is blown and the 4-5 and 5-6 coils are at the tolerance limit. According to the FSM, resistance betwen 1-2, 2-3, 4-5, 5-6 should all be within 28-33 ohms for the original coil. I think the newer ones (like those sold by dsmisc.com) have coil resistances nearer to 40 ohms. 76 is way out though. He could un-solder some of the good coils from the JY one and solder them in to the old one, but I think that's perhaps a stop-gap solution based on the age and condition of the coils.
Eric W.
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6074 MB (Peak: 0.6631 MB) Data Comp: Off Server Time: 2026-06-21 23:41:49 UTC
