trying to save gas #886760 05/20/08 11:44 PM
jbogan67 Offline OP
well i was trying to save gas and my jeep grand is awd so i decided to pull the front drive shaft and now the jeep rolls when in park. i read about a recall on this same situation but it worked the minute before i took out the shaft
Chicks Dig Body Damage
Re: trying to save gas [Re: jbogan67] #886761 05/20/08 11:48 PM
Bigbird79 Offline
If your jeep is AWD, it has a center diff in the transfer case.
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: trying to save gas [Re: Bigbird79] #886762 05/21/08 12:53 AM
BigJim Offline
Yep and that diff is now unattached to the front wheels so you will roll without using the park brake.
Re: trying to save gas [Re: jbogan67] #886763 05/21/08 01:11 AM
E
el_d_m Offline
you can increase some mileage by adding 2 ounces of acetone per 10 gallons of GASOLINE not diesel. i have been trying this for 2 tanks now & i have gotten about 1 1/2 mpg extra. i also have a fitch fuel catalyst system on my xj & it added about 2 or so mpg.
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
Re: trying to save gas [Re: el_d_m] #886764 05/22/08 10:00 PM
jstritec Offline
Fitch Fuel Catalyst = Snake Oil
Certified by the EPA under 40CFR85.2114 !!!
http://edocket.access.gpo.gov/cfr_2003/julqtr/40cfr85.2114.htm
Which says in a nutshell...
It is guaranteed by the feds that it wont make your car's emissions worse!
For 223 bucks (as advertised on summit)I'd fill up my gas tank a few times and not look back
Josh
80 CJ-7.
It runs
Re: trying to save gas [Re: jstritec] #886765 05/23/08 12:01 AM
the_other_guy Offline
with a center diff, and no front driveline, wouldnt the car not be driveable at all? or does it have a limited slip in the center? just kind of curious about that.
Your road to glory will be rocky, but fulfilling.
- Panda Express fortune cookie
94 YJ. no lift...YET
Re: trying to save gas [Re: the_other_guy] #886766 05/25/08 12:17 AM
jbogan67 Offline OP
drove great just didnt go into park.
Re: trying to save gas [Re: jbogan67] #886767 05/27/08 07:39 AM
BobRowe Offline
Your AWD vehicle has a differential or some type of viscous coupling in between the two axles. If it is an open diff, you wouldn't be able to move with the front driveshaft disconnected. Since you can move, that indicates that you have an LSD in that center differential. If you drive it continuously with the front drive shaft removed, there is a decent chance you'll wear out that LSD fairly quickly. It would be like driving a vehicle with a rear LSD and one rear axle shaft removed.
Re: trying to save gas [Re: BobRowe] #886768 05/28/08 03:06 PM
O
oldgreen Offline
Seriously if you are so gung ho to save gas go buy a small 4 cylinder car. jeeps at this time just aren,t great gas mileage machines.
84 CJ7 304 HEI 35 BFG,s rear dana 60 with detroit locker,Viar compressor, fibreglass body, 2 1/2 spring lift, TF999auto, Warn 8000 winch, Plus a cool little trailer on 35,s. JEEP stands for just empty every pocket
Re: trying to save gas [Re: BobRowe] #886769 05/30/08 01:21 AM
cjensen Offline
Me think's I'd put da shaft back in before u get the shaft. A few bucks on fuel now....or a whole lotta more later!
C.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6324 MB (Peak: 0.7396 MB) Data Comp: Off Server Time: 2026-06-13 13:20:56 UTC
