Re: welding gears [Re: FatTony] #887076 05/24/08 01:27 AM
barlown Offline OP
Thanks man I don't mean to sound like a dumba$$, but I have no idea what a third member is or how I can get any room in the case to do anything without taking the flange off. So if you have any help I would appreciate it. Only my axle seals are leaking not the seal by the flange. Thanks again for everybodies help
88 montero 3'' body lift, torsion crank, shackles, 32'' tires 200,00 miles and going
Re: welding gears [Re: barlown] #887077 05/24/08 07:30 PM
icysyrup Offline
are somewhat mechanically inclined..it wont take but an afternoon of your time. The chipping of the slag is what draws it out. Biggest point I can make to you is clean and then clean some more to get all the oil out.
Here is a bunch of pics....you need to take the ring gear off as LR said and then you will see the 4 points to weld on the spider gears where they are circled. Hope this helps.
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: welding gears [Re: icysyrup] #887078 05/24/08 10:15 PM
FatTony Offline
This piece is known as a third member. As you can see, the pinion flange is still on. To remove it you have to take out the axles, then just take off the nuts and pull it off the studs.
88 Raider sas, doubler, boggers
Re: welding gears [Re: FatTony] #887079 05/25/08 02:24 AM
Chris_J Offline
Has anyone tried to Contact Aussie Locker about an EZ Locker for the front axle? I would buy one if the price was right 300ish ballpark. They make them for the IFS on the Isuzu's. Just a thought.
Re: welding gears [Re: Chris_J] #887080 05/25/08 05:38 AM
look on australian ebay and trademe websites those things are for sale on there all the time, i think they're discontinued though, but i think it would cost big bucks to ship.
Re: welding gears [Re: TOASTY] #887081 05/25/08 03:31 PM
Chris_J Offline
An Aussie Locker is just an EZ locker. Replaces the Spider gears, not a full Carrier replacement.
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.013s) Memory: 0.6179 MB (Peak: 0.6889 MB) Data Comp: Off Server Time: 2026-07-14 08:18:24 UTC
