Page 2 of 3 1 2 3
Re: head compatibility [Re: Ezrider_92356] #887395 06/01/08 11:08 AM
E
Ezrider_92356 Offline OP
well i found another problem upon removing the timing cover looks like the drivers side guide broke and the chain was rubbing the cover and wore into the watter pump housing causing a small threw crack that you can see light threw, i wonder how that oil got in the coolent..lol ill try to take some pictures tommorrow
will defently be going with upgraded guides this time no more plastic *****
Re: head compatibility [Re: Ezrider_92356] #887396 06/01/08 07:53 PM
Staceman Offline
You can get you a new timing cover from EB for 50-ish bucks.
I'd order it now and you can install it as they finish up your head. You can get a new timing kit too from EB, with the steel guides, rather than plastic.
Is all of the plastic guide that broke, all there? If pieces are missing, then they worked their way down to the oil pan. IF this is the case, you'll wanna remove your oil pan to get those pieces outta there. Those pieces will block the oil flow at the sump screen, and stop oil flow in the engine. Trust me, I bought a used engine with a "rattle" problem. Wasn't a rattle, is was a knock - bad knock. Ended up rebuilding the entire engine, because plastic guide pieces were blocking all oil flow.
Re: head compatibility [Re: Staceman] #887397 06/02/08 07:44 AM
E
i will be calling EB monday morning and ordering a new cover and steel guide timming set. hopfully ill get it around the time that i get my head back.
the peices were sitting right at the bottom of the timming cover they were too long to make it all the way into the pan. i may go ahead and pull the pan. my question is should i go ahead and replace the oil pump or just swap my existing one onto my new cover.
Re: head compatibility [Re: Ezrider_92356] #887398 06/02/08 08:01 AM
kewlynx Offline
The pumps are pretty bulletproof; so your choice.
x2 on removing the oil pan and cleaning out the debris. The boss for the drain plug stands up about an inch, so you never get the bottom junk out.
**ubi apis- ibi salus**
Re: head compatibility [Re: kewlynx] #887399 06/02/08 09:12 AM
E
i think i will pull the oil pan it will be a good oportunity to clean it out realy good anywhaz, ill probably re use the old oil pump it showed no signs of going out and although im not wanting to be cheep on this project as i want it to last but theres no need to spend needlessly
Re: head compatibility [Re: Ezrider_92356] #887400 06/03/08 02:58 AM
E
i got my timming set and valve cover orded today from eb will be shipped out tommorrow. also any word on what size tap and die i need to chase the head bolts and holes
Re: head compatibility [Re: Ezrider_92356] #887401 06/03/08 07:23 PM
E
well now i have an not so happy post to make, i got a call from the mechine shop today and they said that they are going to have to order quite a few parts for my head and its going to cost about an extra $100 i was at the machine shop and talked to one of the workers a few days ago and they had said my parts were already ordered, i get the feeling there trying to shaft me out of $100. i told them to save all the bad parts because i want to see them
Re: head compatibility [Re: Ezrider_92356] #887402 06/03/08 08:10 PM
Red_Chili Offline
Toyota Section Staffer
12mm x 1.25mm
I doubt they are trying to screw you, most of these little machine shops are reputable. By chance were they valve guides , seals, and/or screw tappets? If so, not surprising at all.
-Bill
Re: head compatibility [Re: Red_Chili] #887403 06/03/08 10:56 PM
E
well i went down to the mechine shop today and took a look at things, and im not so mad anymore, one of the valves was worn so bad is looked like a half moon and was almost sharp enough to shave with and the rest of them were worn to the point where they would have been out of spec by the time they were machined, and there was quite a bit of play in the valve guides.
Re: head compatibility [Re: Ezrider_92356] #887404 06/04/08 06:56 PM
Red_Chili Offline
BTW, though I used a tap to clean out carbon in the hole between #3 and #4, and that should be fine, EB replied to me thusly:
>The reason we use a thread chaser is a tap cuts 75% thread contact, at least
>most do while the bolt threads are 90%.
>The difference in pitch can remove metal so there is a small risk of
>stripping the threads out. Usually it is fine, I am just overly fussy since
>if I mess something up I can cause folks trouble.
>It should be fine.
>Ted
-Bill
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6391 MB (Peak: 0.7478 MB) Data Comp: Off Server Time: 2026-07-16 01:39:59 UTC
