Re: Body swap? Possible? [Re: FrankR] #888102 06/02/08 01:54 AM
<img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: Body swap? Possible? [Re: FrankR] #888103 06/02/08 02:43 PM
hazy_daze Offline
Thought it was against Da Rules to post pornography or overly suggestive images on the wire <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Body swap? Possible? [Re: hazy_daze] #888104 06/02/08 09:55 PM
Seems to me like with all the $$$ Frank saved with the wife's Santa Fe, he ought to be slapping one of those bad boys in and done with his S/C shenanigins... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Body swap? Possible? [Re: MontyMcV] #888105 06/02/08 10:30 PM
FrankR Offline
I'm looking at it, but want to wait until I get the yard open - then I'll have plenty of parts and can cut up a Montero frame for a "true" engine/transmission/firewall rolling chassis jig and pull a 3800 engine for test fitting with the various transmission/t-case options.
Even if it all will fit, there's still a lot of work to make that swap. I might even prefer to use another truck for any attempt if the present truck is running ok.
We'll see - first I need the space, a welder, the parts (cheap) and the time.
I do like that swap, but I wish the 60* 3900 engine had a factory blower package. I think the 90* engine will be a tight fit side-to-side.
Frank
Re: Body swap? Possible? [Re: FrankR] #888106 06/03/08 12:54 AM
I wonder if there is a trade off between the 60* and 90* in the form of the whole blower/intake assembly sitting lower in the 90*, and thus clearing the hood better.
Haven't kept up on yours, is it fitting under the hood okay?
Re: Body swap? Possible? [Re: MontyMcV] #888107 06/03/08 01:24 AM
FrankR Offline
Sure there is - the 90* sits lower and the lower intake manifold would be easy to adapt to a blower even if one wasn't already available. The width is one issue, but the other is that 90* V6s usually need balance shafts where 60* V6s do not. Any serious buildup of a 3800 requires a double roller timing chain which means elimination of the balance shaft. The solution is to balance the rotating assembly, but I don't know if it gets rid of all vibration or not. I would expect it would be ok if extremely close attention was paid to weight balance, bore alignment angles and power balance - making sure that each cylinder produced equal power.
Mine has a small scoop about 2" in height for blower clearance.
The 3800 might fit without a scoop, but I suspect the oil pan would have to be highly modified.
Frank
Re: Body swap? Possible? [Re: FrankR] #888108 06/03/08 02:43 AM
hazy_daze Offline
A body lift would make some more room.
Re: Body swap? Possible? [Re: hazy_daze] #888109 06/03/08 06:55 PM
I think a BL would effectively lower the engine and make the 90* deeper into the wheel wells. If it's the wideness of the 90* that seems to the challenge, not sure lowering the placement will help.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6350 MB (Peak: 0.7299 MB) Data Comp: Off Server Time: 2026-06-18 13:14:31 UTC
