Montero addiction, another dead 95' SR #888149 05/30/08 11:12 PM
sewerrat Offline OP
I've been "clean" for 6 months. Then I fell off the wagon behind a cheap used car lot. <img src="/forums/images/graemlins/evil.gif" alt="" /> Just stopped to take a look, whats the harm? Minor front body damage, locked up motor, torn seats, dirty/missing carpet. The dealer made me an offer I couldn't pass up. Fixed a no start problem on a Toyota, got the monty for $1.08 <img src="/forums/images/graemlins/wink.gif" alt="" />
The body stuff is repaired, dead motor removed. Have several choices for motors. A "good runner" 3.5DOHC for $2100, E-Bay 3.5's for $1500 ect. Tempted to try a 3.8 Mitsu swap but that might be more than I want to deal with.
At least I have a reason to lurk around here now. <img src="/forums/images/graemlins/cheers.gif" alt="" />
95 Montero SR 3.5 sitting on the sidelines.
96 Montero LS Daily driver.
88 Audi 90 Quattro marking it's territory.
69 Bronco built but uncut garage queen.
TANSTAAFL
Re: Montero addiction, another dead 95' SR [Re: sewerrat] #888150 05/30/08 11:25 PM
sparkem Offline
My bro has a 120k mile or so rolled 95SR in LA if you would be interested. Kinda of a long drive.
Re: Montero addiction, another dead 95' SR [Re: sparkem] #888151 05/31/08 01:51 AM
ryany Offline
There's an ad on the Phoenix Craigslist for an engine & trans from a 98 Montero. That would be the 3.5 SOHC instead of the DOHC that you have but some mixing & matching of parts could yield a running motor for not too much $$$.
http://phoenix.craigslist.org/pts/672466398.html
95 Montero SR
Re: Montero addiction, another dead 95' SR [Re: ryany] #888152 05/31/08 06:02 AM
sewerrat Offline OP
Thanks for the replies.<img src="/forums/images/graemlins/kewl.gif" alt="" /> Louisiana is tempting, been too long since I've been out that way. Phoenix is a bit closer, but still a haul.
Found a 1997 3.5sohc a few hours from here. Still in the truck, they will let me run a comp test, but they won't let me remove it. <img src="/forums/images/graemlins/frown.gif" alt="" /> The pricy mill in SLC was run, good comp test, 110000mi, they will let me pull the lower oilpan and 90day return. At least between Denver and SLC, if I see something I don't like, I can leave it and not feel too bad.
Thanks again....
TANSTAAFL
Re: Montero addiction, another dead 95' SR [Re: sewerrat] #888153 06/10/08 05:10 AM
sewerrat Offline OP
It's alive! <img src="/forums/images/graemlins/wink.gif" alt="" />Found an engine in Vernal UT. (car-parts.com). Runs good, no ticking, but smokes after idleing. The heads from the dead engine did not crash, so I'm going to clean, check out, refresh and swap + t-belt stuff.
Driving the Gen II is great. Lots more power than the 3.0, feels better at speed. Holds 75mph w/no trouble. Put on about 200 miles so far, first mileage check showed 18+mpg.
<img src="/forums/images/graemlins/cheers.gif" alt="" /> Bob
TANSTAAFL
Re: Montero addiction, another dead 95' SR [Re: sewerrat] #888154 06/10/08 02:40 PM
V
vr4 Offline
did you tear down the old engine yet? i just picked up a 95 3 weeks ago with a locked up motor too. the carnage was amusing.
have an upper oil pan?
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: Montero addiction, another dead 95' SR [Re: vr4] #888155 06/10/08 05:53 PM
sewerrat Offline OP
The upper pan looks intact, but the windage tray is mangled from the con rod. The main cap/web has a chunk missing as well. The cyl. wall is damaged, the top half of the piston stayed in the bore. Nothing hit the head, they both are checking out flat/clean. No signs of damage to the cam bores. This one must have had a quick death.
Another 3.5 I pulled apart had tons of metal chunks in the head, wiping out the cam bearing surfaces, locking the valve lifters in the bores. The crank in that one had wiped out the main bearings, and chewed into the block. <img src="/forums/images/graemlins/barf.gif" alt="" />
These are tough engines but "The addition of oil is not retroactive" <img src="/forums/images/graemlins/lol.gif" alt="" />
TANSTAAFL
Re: Montero addiction, another dead 95' SR [Re: sewerrat] #888156 06/10/08 06:53 PM
And that a few of us truly agree with while others have yet to learn.
Kind of goes with coolant too.
The windage tray should be quite cheep from a dealer.
Re: Montero addiction, another dead 95' SR [Re: OldColt] #888157 06/10/08 07:27 PM
V
vr4 Offline
yours sounds more thrashed than mine. mine dropped the con rod cap off thanks to driving for who knows how long with a spun bearing, smacked the side of the upper pan and cracked it, snapped 1 of the pan bolts off clean. slight ding in the windage tray but not bad. piston hit the head but no damage to the valves. 1 of the mains was pretty trashed but the other 3 were ok??? block and girdle undamaged. heads were ok (just redone with all 24 valves and 12 guides 2300 miles ago. receipt in truck)
i have a thread in parts wanted looking for an upper pan <img src="/forums/images/graemlins/wink.gif" alt="" />
91 MR2 turbo
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6335 MB (Peak: 0.7381 MB) Data Comp: Off Server Time: 2026-06-10 21:07:44 UTC
