Mazda Fuel Injection Swap
#888290
06/01/08 04:11 AM
A friend of mine had a Mazda MPV, which he says had the same Mitsubishi 2.6 in it that I have only fuel injected. He says that the B2600's have the same motor too. Is this true, and if so has anyone tried swapping the fuel injection onto a Gen 1 2.6?
88 Raider sas, doubler, boggers
Re: Mazda Fuel Injection Swap
[Re: FatTony]
#888291
06/01/08 01:17 PM
Not true for the MPV, that would have the Mazda designed and made B6 engine, before the B6 Mazda did use the G54 in the pickup for a couple years.
[Re: OldColt]
#888292
06/01/08 06:20 PM
those 2.6's also have different heads, the intake and exhaust are on oppisite sides to the montero.
[Re: TOASTY]
#888293
06/02/08 05:35 AM
87-88 Mazda b2600 used the Mitsubishi G54B, but alas it was carbed as well.
Kane
89 Conquest - 2.4 DOHC <--Thats right DOHC Turbo and MPI. 87 Starion flatsider - under restoration 87 Conquest - Saved from the crusher 86 Conquest - Another crusher rescue 88 Conquest - Previous owner abandoned project 87 Raider - under construction
86 Conquest - DD
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6013 MB (Peak: 0.6568 MB) Data Comp: Off Server Time: 2026-06-16 09:56:37 UTCValid HTML 5 and Valid CSS
