Brake warning light stays on, then goes off then comes on again...?
#888313
06/01/08 07:30 AM
The brake warning light in my 1990 Pajero LWB auto stays on in the morning after I start up and drive off. It's not the handbrake because if I leave the handbrake off overnight, the light is still on when starting up in the morning. I took the sensor wire off the brake booster, and earthed it but that makes no difference. When I take the low level sensor connection off the master cylinder the light goes out, and comes on again when I connect it up again. The master cylinder is full of fluid. During stop start driving during the day the warning light goes off, but sometimes comes on again if I brake.
Any Ideas anyone? I've checked the booster in the normal way and it seems fine. Braking seems normal as well. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Brake warning light stays on, then goes off then comes on again...?
[Re: bergie]
#888314
06/01/08 07:37 AM
is the float in the reservoir stuck?
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#888315
06/01/08 10:00 AM
I don't think so, but I'll check in the morning. Thanks, Bergie
[Re: bergie]
#888316
06/01/08 12:51 PM
If you can't find anything wrong with the fluid level, fluid reservoir switch or parking brake switch, check the alternator.
Frank
[Re: bergie]
#888317
06/01/08 01:09 PM
I don't think so, but I'll check in the morning. Thanks, Bergie On POC(uk) this has popped up an a number of occasions, usually the float switch but these are sensative to small drops in fluid level & just adding a small amount of fluid will solve the problem. I'll go with fluid level, as you say that the light goes off during stop/start driving which will heat-up the fluid & it expands a little. SteveN <img src="/forums/images/graemlins/wink.gif" alt="" />
Shogun (Pajero/Montero) 3.0L V6 12valve LWB Auto 1993 142k miles. Dual Bouncy Seats Totally stock c/w Diff lock now sold
[Re: StockRaider]
#888318
06/01/08 06:12 PM
is the float in the reservoir stuck? Mine sticks sometime also and it's been the float in the reservoir. I think I need to clean the brake fluid system as it look dirty.
Michael j
TreadLightly! Trainer
[Re: Grasscat]
#888319
06/02/08 10:48 AM
After startup this morning I poked the float in the master cylinder and the brake warning light went out. DUHHH! Why didn't I think of that. Thanks everyone. Bergie.
[Re: bergie]
#888320
06/02/08 03:22 PM
Can you post a photo of how you did this so other folks can follow your lead? Thanks!
R.
89 Raider V6 95 SR Montero
[Re: Crops]
#888321
06/02/08 04:04 PM
You take off the lid on the master cylinder and poke your finger down in the reservoir. All there is too it.
[Re: hazy_daze]
#888322
06/02/08 05:25 PM
You take off the lid on the master cylinder and poke your finger down in the reservoir. All there is too it. What "hazy-daze" said except, poke your finger on the float, in the reservoir. Just dislodge it. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael j
