Re: Fuel pump/tank, POR-15, Frame rust repair [Re: Red_Chili] #888707 06/06/08 05:06 AM
OOP'S Offline
You must be left handed, David?
Agreed, nice work.
Yes they are nice looking welds, but they are not mine. A friend of mine who is a pro welder came to my house and did them for me. He is on PBB a lot with the screen name of Booger Welds, that is what his welds looked like before he took a pro welding course and is a certified welder now.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Fuel pump/tank, POR-15, Frame rust repair [Re: Vanishing_Point] #888708 06/06/08 02:25 PM
Red_Chili Offline
Toyota Section Staffer
Not to step on anyones toes, but frame repairs are best if the patch panels don't have straight edges. Fish plates are best. You should also be carefull about welding perpendicular to the frame rails.
Generally true, but I don't think it matters much on Toy frames.
Except for near the front spring hanger, front axle.
-Bill
Re: Fuel pump/tank, POR-15, Frame rust repair [Re: Vanishing_Point] #888709 06/07/08 04:56 AM
OOP'S Offline
That is true, as long as you make the ends of the plates with some kind of angles on the ends you will be fine. Like this / /, \ \, < >, > >, / \, ( ), ) ( will all work. I worked with an old man repairing big rig trailer frames for many years. The only thing he did not teach me was how to weld. This was before the days of wire feed, so everything was done with a big 350 amp AC/DC stick welder. Man that dude could make some pretty welds with that thing, flats, fillets, verts, and overhead.
David Fritzsche
Roseville, CA
Re: Fuel pump/tank, POR-15, Frame rust repair [Re: Bolosh] #888710 01/04/10 04:06 AM
matts Offline
Nice work. It's always good to see a 20+ year old Toyota 4x4 getting rehabilitated. I did frame repairs on my '84 that were way more extensive. I got another five years (winters) out of my decrepit frame after the repairs. Recently though the last two and a half feet of the frame rails really started to disintegrate. It's out of service now, but I hope to get a complete used frame and bed (it will be the third bed) to bring it back to life at some time in the not too distant future.
If I had to run these '84 - '88 trucks/4runners in the snow and salt again I'd try to do something about the "swiss cheese" effect that the many unused holes in the frame present. I'd seal um up and leave only the front and rear ends open. I'm sure these things would last two or three times as long if they could be kept dry and salt free on the inside.
Here's some pics of my work. Notice that I didn't make any angled cuts on my patches :-)
Re: Fuel pump/tank, POR-15, Frame rust repair [Re: OOP'S] #888711 05/27/13 12:54 PM
A
age67 Offline
Not questioning your knowledge, but why use 1/4" plate to patch the holes in frame. I need to know as I have to patch the rear of frame on my '88 Dodge Raider the last ten or so iches in the rear in pitiful shape, it appears to be 1/8".
I could not open the pictures you posted, can you give me an idea how I may open them.
Thanks, Eddie
'88 Dodge Raider 2.6L, 5 spd.
Re: Fuel pump/tank, POR-15, Frame rust repair [Re: age67] #888712 05/27/13 02:39 PM
G
Greg_Canada Offline
Probably what he had... 1/8 to 3/16 should be more than thick enough.
89 4Runner
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6182 MB (Peak: 0.7062 MB) Data Comp: Off Server Time: 2026-07-17 07:48:15 UTC
