Page 2 of 3 1 2 3
Re: Looking to find a GM 14 bolt for the rear axle of the TJ. [Re: reepersteve] #888862 06/11/08 03:14 PM
Brown81CJ5 Offline
Not to mention that you can get a high pinion 9 inch...don't think the 8.8's came in a HP version.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Looking to find a GM 14 bolt for the rear axle of the TJ. [Re: Brown81CJ5] #888863 06/11/08 11:12 PM
reepersteve Offline OP
Exactly. I also read some where that there was a 9 with a large 9 on it. They called it a Super Nine. <img src="/forums/images/graemlins/mrt.gif" alt="" /> Or some thing to that effect.
Any one have info on 9's that would fit? I have a 01' TJ.
01' TJ Wangler, 6" Ruff Country X Series, 35" x 12.5" Mickey Thompsons On 15 x 10" rims w/ simi Bead Lock, Matching Warn Bumpers, 9500xi Warn Wench, Tom Woods Drive Shaft And SYE, And A K+N Cool Air Intake. Still Improving
Re: Looking to find a GM 14 bolt for the rear axle of the TJ. [Re: reepersteve] #888864 06/12/08 02:38 PM
DBL_DTY97TJ Offline
Google SunRay Engineering in texas. They build custom 9" for Jeeps and would prolly be happy to talk to you for a few minutes about what you need to look for. Or convince you to buy one of their custom ones...$$$, but worth it IMHO. <img src="/forums/images/graemlins/cheers.gif" alt="" />
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Looking to find a GM 14 bolt for the rear axle of the TJ. [Re: reepersteve] #888865 06/12/08 08:35 PM
BigJim Offline
Steve you can go to craigslist.org and surf "autoparts---search--- 9' axle" In cities all over america.
Just yesterday I spent a couple of hours looking for a 99 Ranger front axle and hub.. I found it in a city in California.. It is presetly in a UPS carrier and on it's way here.
While searching for "front axle" Many 9's were included in my search as they were in an ad for a front axle also.
I do try to stay out of the RUST BUCKET cities but so far I have had good luck with craigslist and eBay.
Re: Looking to find a GM 14 bolt for the rear axle of the TJ. [Re: BigJim] #888866 06/16/08 03:05 PM
superdawg Offline
I build custom axles, that is by biz.
Before you buy a Craigs list anything, PM or email me.
If you want me to quote out an axle build, let me know.
SD
Josh
Re: Looking to find a GM 14 bolt for the rear axle of the TJ. [Re: superdawg] #888867 06/17/08 02:44 AM
I like the width of the stock d30/d35. Hoping not to have to change that.
Super, do you know the widths of hand, I haven't got around to it. Lazy I guess <img src="/forums/images/graemlins/sleeping.gif" alt="" /> Yhat would probly be a good start. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Looking to find a GM 14 bolt for the rear axle of the TJ. [Re: reepersteve] #888868 06/17/08 02:42 PM
Brown81CJ5 Offline
Hey Steve, check this website out.
Gun it and run it!
Re: Looking to find a GM 14 bolt for the rear axle of the TJ. [Re: Brown81CJ5] #888869 06/17/08 11:57 PM
Nice site. I was reading the Latest JP mag today, and was thinking of going through Curry. Hell, after the seach and rescue, the tear down, the rebuild and install. All the querks and extra $$$$ spent trying to make it right.
I will probably end up spending the same money and less time going there.
I looked at the site Brown kicked out and it pretty muck threw me there way. I looked at there site and came up with the part # CE-JTJ9704X. <img src="/forums/images/graemlins/mrt.gif" alt="" />
Just don't like the price, OUCH!!!! <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" />
Super, do you think you can beat the price with the same quality?
9" Plus Round Back HD Housing
31 Spline Currie Axle Package
Stock Width and Pinion Agle
Suspension Brackets and Spring Pirches Installed
TorinoStyle Late Model Large Bearings
5 on 4 1/2 Or 5 on 5 1/2 Patterns
Studs Are Allready Installed With 5 on 4 1/2
1/4" Thick Bearing Retainer Plates
Tapered Timkin Wheel Bearing Pressed In
Excepts 11" Drums or 11" Ford Exp. Disks
Re: Looking to find a GM 14 bolt for the rear axle of the TJ. [Re: reepersteve] #888870 06/22/08 01:09 PM
superdawg Offline
I can beat Curries with no problem.
I build 9s with 35 spline shafts if you are going to spend good cash, you might as well make it bomber.
I can build D60s pretty reasonable too.
Email me.
joshua@crawlertech4x4.com
sd
Re: Looking to find a GM 14 bolt for the rear axle of the TJ. [Re: superdawg] #888871 06/23/08 11:49 PM
Tried to PM you some thimg is wronge with my yahoo SH!T! I do want to respond to you and get some info.
Try me at swjoiner28@yahoo.com
Thanks
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6434 MB (Peak: 0.7531 MB) Data Comp: Off Server Time: 2026-06-07 10:31:59 UTC
