Re: Engine Swap V/S Raider Swap [Re: FatTony] #889210 06/08/08 05:11 PM
This is what I build at work.
http://ificanada.com/MINECATUT99Brochure.pdf
Cool job! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Engine Swap V/S Raider Swap [Re: MontyMcV] #889211 06/08/08 06:40 PM
G
generation_one Offline
I couldnt get to see the link...
is it those 95 foot tall trucks ?
you should find diesel engines to swap in, not 4.3's
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: Engine Swap V/S Raider Swap [Re: generation_one] #889212 06/08/08 11:54 PM
FatTony Offline OP
No, these look like a Jeep with a box. I am looking for a diesel too, but there aren't that many options that I like. The mitsu diesels don't have the power I am looking for, and pick up diesels are too big. I like the looks of the cummins 4bt but they're about 3500-4000 bucks just for the motor, plus adapter plates etc.
88 Raider sas, doubler, boggers
Re: Engine Swap V/S Raider Swap [Re: FatTony] #889213 06/09/08 06:58 AM
LandRaider Offline
It really depends on what you want for a final product.
Downsides.
#1 your truck wont work for months
#2 it is going to be difficult to chase all the details out.
#3 it's gonna be expensive
#4 it's gonna take more time than you thought, and be more expensive than you thought.
#5 You're going to have to learn GM EFI and GM electrical systems..... may, or may not be a problem.
#6 It is going to be what you put into it. It will be as reliable as you engineer it to be.
Things I like about my truck.
#1 it hauls ass
#2 it will get 20 mpg when driven conservatively.
#3 it is easy to work on.
#4 is reliable
#5 parts are common, and cheap....
water pump 15.99
alternator 80 bucks
starter 50 bucks, and takes 5 mins to change.
#6 no timing belt to EVER wear out, and grenade my motor.
#7 No retard wiring stuff. (white with blue stripes, and red speckles with yellow bands)
<img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
#8 2.72:1 low range. While it's nothing to brag about, the fact that I got it as a bonus is awesome. (terra low kits are redaily available.
#9 my truck will run upside down, and I never have to look at a stupid carb ever again.
Those are the things I come up with off the top of my head.
Ive driven 2.6 raiders, and 3.0 raiders... Had a 2.6 turbo in my truck before I went 4.3. None of them drive as good as mine does now. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Engine Swap V/S Raider Swap [Re: LandRaider] #889214 06/12/08 02:32 AM
FatTony Offline OP
I agree on all points Landraider. I've done engine swaps in stuff before, and I know that no matter how well you estimate you can always add a couple hundred bucks and a couple days/weeks to your plans. Looks like the swap is on for sure. Decided I don't want the other raider. May end up with a V8, other than firewall/rad support mods it's pretty much the same amount of work. Depends on if I can find a good donor 4.3 vehicle. Going to look at an AWD astrovan next week, we'll see how that works out.
Re: Engine Swap V/S Raider Swap [Re: FatTony] #889215 06/17/08 02:51 AM
FatTony Offline OP
Thought I'd update. Ordered a 2" Body lift today to clear the new drivetrain, still working on a GM donor vehicle, nothing has worked out as of yet. May have a line on a 1995 Blazer with low KMs for cheap (rearend is blown) but not sure yet. Played with the Carb more and got the 2.6 running a little better, but she's still pretty tired.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6161 MB (Peak: 0.7039 MB) Data Comp: Off Server Time: 2026-06-09 10:12:28 UTC
