Re: '86 vibrations while coasting down hill. [Re: AZcoma] #889362 06/09/08 10:54 PM
4Crawler Offline
With lift springs, no shims are typically needed with the stock single-cardan shaft, however, with the 2" longer shackles, you generally need about a 2 degree shim to tip the pinion down:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ12
- http://www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml#FixingProblems
Re: '86 vibrations while coasting down hill. [Re: 4Crawler] #889363 06/13/08 06:00 PM
A
AZcoma Offline OP
good news is the vibration has reduced substantially. But, I'm going to reinstall the shims/wedges again only with the thick end facing the front of the truck. With a 6 degree difference (83 at the xfer case and 77 at the diff.) the shims I have are @ 3/8" thick. That should narrow the angle difference to within a couple of degrees (I hope).
'86 4x4 SR5 22re 5" lift 35" BFG's and 5:29 gears.
'05 4x4 DC Tacoma TRD Sport
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5960 MB (Peak: 0.6447 MB) Data Comp: Off Server Time: 2026-06-07 02:17:01 UTC
