injectors not firing #889666 06/09/08 02:16 AM
JD9996 Offline OP
I have a 1990 3.0 v6, I took a test light and checked power at harness and had power on both legs and tried to crank engine and still had power on both legs with no ground pulsing. What is the next thing to check? Thanks!!
Re: injectors not firing [Re: JD9996] #889667 06/09/08 03:51 AM
4Crawler Offline
Likely the 3.0 is the same as the 2.4 engine, the grounds run back to the ECU. Usually the ground wires from the injectors tie together and run back to 2 grounded pins on the ECU (No10 and No20 in the 2.4 ECU). Search the forum for "Injector Wire Splice" and and see if that issues applies to your case.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5874 MB (Peak: 0.6352 MB) Data Comp: Off Server Time: 2026-06-08 20:53:02 UTC
