Air bag warning light. #890799 06/15/08 10:03 PM
BigR61 Offline OP
Happy Fathers day to all <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> . Started the Sporty this morning and the air bag warning light started blinking, got the code reader and all I'm getting is a IAT sensor 1 circuit low imput code. Tried reseting the light but still blinks, took the fuse out but the light stays on and as soon as you put the fuse back in, it starts blinking again. It's a 99. Anybody know what's going on. Thanks.
90 Cherokee Laredo
98 Cherokee Classic
www.cardomain.com/ride/2986792
Re: Air bag warning light. [Re: BigR61] #890800 06/15/08 10:43 PM
Axe Man Offline
Kia Moderator Emeritus
The airbag ADU has sensed some sort of fault. Unfortunately you cannot diagnose nor pull trouble codes from the airbag system with a generic OBD-II code reader. You must use a Kia Pro Scan Tool. Only dealers have access to this tool. You have no choice but to schedule a visit with a Kia Dealer.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: Air bag warning light. [Re: Axe Man] #890801 06/17/08 05:01 PM
logansportage Offline
FYI, they will charge you to pull this code. So, expect to pay out the nose for the tech to tell you someone hit your front bumper hard enough to trigger the sensor but since the car was not on at the time the air bag was not deployed.
He'll probably tell you they need to replace the sensors which will cost you $$$.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5926 MB (Peak: 0.6462 MB) Data Comp: Off Server Time: 2026-05-30 05:47:01 UTC
