Page 3 of 3 1 2 3
Re: more power [Re: Hydra747] #891001 06/26/08 07:39 PM
wyodriver4 Offline
it wont be with a turbo. you want the biggest exhaust possible with forced induction. all the air goin in has to be able to get out.
cone filter, boche platinum 4 plugs, 235/75/15 kumho all terrains jeep tj rear springs and rav 4 rear shocks, rocksport gear 4" front springs, warn manual hubs, 2.25 inch exhaust, no cat, 48" thrush glasspack
Re: more power [Re: wyodriver4] #891002 06/26/08 11:48 PM
DEFBOY35 Offline
if i can get my insurance to cover me with a turbo swap, i will be running a 3" exhaust. like said, you want it as free flow as possible. it will let the turbo spool up much faster.
there is no need to worry about any back pressure issues with a turbo as all of your back pressure is created at the turbine.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: more power [Re: Hydra747] #891003 06/27/08 05:10 AM
DennisThompson Offline
Yes I am. I know it will be to big for power gains at first but I hope to have the turbo started before the end of summer. I have a stock Probe turbo and I am going to keep the boost around 8psi so the 2 1/2" should work good. My biggest problem right now is finding a place for the intercooler. I might mount it to my skid plate, move the licence plate, and drill some round holes in it so it can get plenty of air.
Dennis
Re: more power [Re: wyodriver4] #891004 06/27/08 01:09 PM
rallyant Offline
I also love turbo conversions and have thought about where an intercooler could go on a sportage.
Im wandering how one would go above the engine with a custom scoop setup in the bonnet? with a body lift you might have the room?
www.pajerio.com
Pajero iO - Lift and 33s on the way smile
Re: more power [Re: rallyant] #891005 06/28/08 11:30 PM
jaboo5322 Offline
I've allways been curious. I have found cheep turbos on ebay that look complete, but do you have to remap the ecm to run the extra boost? I am kinda ignorant in this erea.
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: more power [Re: jaboo5322] #891006 06/29/08 11:13 PM
DEFBOY35 Offline
you would definitely want to have some tuning work done to the ecm if you are running boost!
i think if i end up doing it, i will probably run a stand alone unit in place of the stock ecm, or in my case the powerchips ecm.
that way you can dial in exactly what you need to be abl to run the boost you want safely.
Re: more power [Re: DEFBOY35] #891007 06/30/08 04:18 AM
I have been told since we have a MAF instead of an air meter the stock ECM should be ok, If not my boy is good with stand alones and we will have to build one. I will let everyone know when it happends.
Dennis
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6260 MB (Peak: 0.7006 MB) Data Comp: Off Server Time: 2026-06-07 05:53:06 UTC
