Re: upgrading Alternator wiring for high amp output [Re: Nick Muzzio] #891020 06/20/08 02:12 AM
mlclark Offline
Isuzu Moderator
Yes, the charge wire should be on a ring terminal on the back. You should be fine stacking a second one on top of it for the larger wire.
As for adding accessories, you will go to the battery, but not directly. You need (should) use a fuse or some sort of overload protection between your accessory and the battery, and it should be as close to the battery as possible to eliminate a lengthy run of a hot wire before the fuse. This is also a chance to use a power distribution block if you have several items to add. There are endless ways to do the wiring, just pick what works for what you need.
Michael
Re: upgrading Alternator wiring for high amp output [Re: mlclark] #891021 06/20/08 06:35 AM
Nick Muzzio Offline OP
Thanks will do!
91 Trooper LS, 5 Speed Manual
3.4L Engine w/4.3L Throttle Body
Snorkel, 31" Pro Comp MT Tires, 2"lift,
ProComp ES9000 shocks and steering stabilizer
http://members.cardomain.com/sun_thief
Re: upgrading Alternator wiring for high amp output [Re: Nick Muzzio] #891022 06/21/08 10:55 PM
barak Offline
I never upgraded the wire per se when I upped my alt to a 200 amp because of my winch and stereo stuff , but I also put in a box so i can run a battery in the back of the truck that also charges and runs my electric fan and some other small items.I did use 4 guage for those connections which run right to the batteries.
as for you question about pics of the truck , I will have to find them , I am not sure they are all on photobucket anymore , although I did have every picture i took from before I started when I had both troopers , up to now where I have the one that I built from frame up.
If your not too far from the island you could always stop by some time when i am actualy around and I could show you a few things that I did custom.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6023 MB (Peak: 0.6555 MB) Data Comp: Off Server Time: 2026-06-10 06:11:49 UTC
