96 Montero LS front axle parts. Soloniod Valve?
#891527
06/20/08 05:02 AM
Does anyone know ballpark what's the cost of the solenoid valves that engages the the front hubs on a 96 LS? They sit on the inside right fender. I tried cleaning out both and also replaced all the lines I still have the front hub lites flashing and sometimes when I come to a stop I feel the truck shudder as if it just either engaged or disengaged
EDIT... I cleaned up your title, spelling, and Grammar.. Hopefully someone who has some good info for you will drop by soon. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 96 Montero LS front axle parts. Soloniod Valve?
[Re: chris40]
#891528
06/20/08 03:29 PM
What makes you think it is the valves? Did you test them?
'06 Dakota QC 4.7 6sp 4x4 '88 Mighty Max '77 KZ1000 fun old bike
[Re: NathanC]
#891529
06/20/08 04:43 PM
do you have tires of the same size? Those things rarely fail.
92 SR, 285/75R16 Yoko MT ARB locker GAST compressor AirLift 1000 MM10500 Snorkel custom rear bumper 02 Montero LS died protecting the master 08 PowerWagon (stock!)
[Re: Alex Kogan]
#891530
06/22/08 06:25 AM
i had the same issue on my SR once in the last 2 weeks. hasnt happened again. my mazda also has the same issue where it tries to engage the front diff (has the same basic design as the montero) while driving. never did figure out what was causing it so i just leave it locked now and leave the t-case in 2wd.
87 Montero V6 SWB auto. dual bouncies 89 Montero V6 SWB 5 speed. dual bouncies 97 3000gt VR4 upgraded turbos, 10:1, E85 91 Stealth TT twin 18Gs, cams/heads, E85 03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" /> 91 MR2 turbo
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6012 MB (Peak: 0.6568 MB) Data Comp: Off Server Time: 2026-06-12 09:18:47 UTCValid HTML 5 and Valid CSS
