cj7 trying to put 360 in it #891981 06/23/08 12:41 AM
just_got_the_jeep_bug Offline OP
just bought a 1977 cj7 and am trying to put an amc 360 in it. what do i need to do to the motor mounts or were can i buy some?
Re: cj7 trying to put 360 in it [Re: just_got_the_jeep_bug] #891982 06/23/08 04:12 PM
Brown81CJ5 Offline
Quadratec.com has mounts for about $30.
You can also try 4WD.com, or JC Whitney. <img src="/forums/images/graemlins/kewl.gif" alt="" />
What motor did it originally come with?
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: cj7 trying to put 360 in it [Re: just_got_the_jeep_bug] #891983 06/26/08 12:28 AM
BROWNBAGG Offline
why, you are going to break everything, axle transmission, transfer. wont last a year
Re: cj7 trying to put 360 in it [Re: BROWNBAGG] #891984 06/26/08 06:06 PM
playinmud Offline
my brothers is still going around with the stock axles and and trans with 35's on her, its got about 400hp and will smother those 35's like they're nothing down the block
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: cj7 trying to put 360 in it [Re: playinmud] #891985 06/26/08 06:15 PM
BigJim Offline
PIM.. Yeah as long as the tires lose traction... but the VERY first time he gets in a place where the tires DON'T lost traction..BAM! There goes the neighborhood! Them parts can't take 400HP. When the tires are spinning the 400HP isn't getting to the surface! Only when the spinning stops will you and he know where the weakest part of the drive train is.
Re: cj7 trying to put 360 in it [Re: BigJim] #891986 06/27/08 12:39 AM
Bigbird79 Offline
Taking all points of view into consideration, he can always try the swap, and as parts break, either upgrade the broken features or just replace the failed component completely. He just has to understand that he is probably minimum 1.5x the HP and Torque with the 360 than he had with the 6 cyl. Now the other consideration he has in his favor is in Æ77 you could get a V8 in the CJ7, but since he asked about motor mounts I have to assume he has one with a 6 cyl. And like anytime one goes wheeling, he should always make sure he goes with other rigs that are all about equally capable of pulling each other out.
Sean
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6049 MB (Peak: 0.6740 MB) Data Comp: Off Server Time: 2026-11-02 08:36:05 UTC
