Page 2 of 14 1 2 3 4 13 14
Re: New member blah blah blah [Re: MontyMcV] #892000 06/23/08 03:56 AM
V
vr4 Offline
for fixing it i would just go with the electric pump since youre going to turbo anyways. a walbro 190lph inline should be more than enough for the starquest motor but your going to need 1 hell of a regulator to bypass enough fuel to feed that carb properly.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: New member blah blah blah [Re: vr4] #892001 06/23/08 04:08 AM
Bernoulli Offline
I'd replace the radiator and heater hoses for sure. Belts should be a given.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: New member blah blah blah [Re: MontyMcV] #892002 06/23/08 04:13 AM
Cochese Offline OP
I have the 1987 Raider SWB FSM's on the way. <img src="/forums/images/graemlins/smile.gif" alt="" />
1987 Dodge Raider TSi
...it begins.
Re: New member blah blah blah [Re: vr4] #892003 06/23/08 05:38 AM
Cochese Offline OP
I think for the cheap route right now, to kill the leak, I'll go about replacing the seals on the mechanical one.
I'm gonna put a package together when I do the swap and the fuel pump will be included.
Anyone know exactly what seals I'll need? Are they a dealer only part or NAPAvailable?
Thanks guys.
...it begins.
Re: New member blah blah blah [Re: Cochese] #892004 06/23/08 06:03 AM
CapnCrunch Offline
Don't know whether or not they are available at NAPA. The P/Ns are as follows:
INSULATOR, FUEL PUMP (in case your's is cracked, thus leaking)
PNC CODE - 05513
P/N - MD023389
REPL P/N - MD187952
QTY - 1
GASKET, FUEL PUMP
PNC CODE - 05510
P/N - MD023388
REPL P/N - MD190929
QTY - 2
The insulator, you probably won't need, but you'll need the gaskets.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: New member blah blah blah [Re: CapnCrunch] #892005 06/23/08 06:34 AM
Cochese Offline OP
PNC CODE - 05513
P/N - MD023389
REPL P/N - MD187952
QTY - 1
GASKET, FUEL PUMP
PNC CODE - 05510
P/N - MD023388
REPL P/N - MD190929
QTY - 2
Skipper, you are the man. Gonna go pick up insurance and plates tomorrow, then oil it up, drive it to the car wash and spray the hell out of the engine compartment with degreaser. I'll be ordering the seals and insulator and giving it a whirl. So how do I get the motor to TDC for the removal of the fuel pump? <img src="/forums/images/graemlins/smile.gif" alt="" />
...and are you gonna be in Westminster in the near future in need of lots of beer and a project? <img src="/forums/images/graemlins/notooth.gif" alt="" />
...it begins.
Re: New member blah blah blah [Re: Cochese] #892006 06/23/08 08:48 AM
CapnCrunch Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> Maybe a beer or two (I don't drink much), but I make it a habit of not drinking any alcohol at all when I'm packin' heat (and I likely would be). A couple Cokes should do. I'm fairly flexible on when (I think), so let me know when's good for you. I can play a little show 'n tell with my truck as well.
Disconnect the battery (if turning crank with a socket).
Locate the #1 cylinder wire and follow it to the distributor. Note the location of where the #1 plug wire goes into the distributor. Use a grease-pencil or something like that to mark the distributor where that terminal is (but don't mark it on the distributor cap because you're going to be pulling the distributor cap).
Pull the spark plugs out and disconnect the coil wire.
Use a socket on the front of the crankshaft to crank it clockwise (as you're facing the engine) or you can have someone else bump the starter in little bits (just be sure it's safe to do so).
Find the timing marks (on the front cover of the engine near the upper edge of the crankshaft pulley) and as your turning the crank, locate the timing notch on the crank pulley. Get that notch directly lined up with the TDC mark on the timing marks. It's the center-most mark. You'll probably have to turn it the last little bit with a socket...if you do, get your assistant out of the driver's seat to avoid a bad accident. <img src="/forums/images/graemlins/scared.gif" alt="" />
Once the notch on the crank pulley is lined up with the TDC mark, check the distributor rotor. If the rotor is pointing at the mark you made on the distributor earlier, then you've got it set to #1 TDC on the COMPRESSION stroke and you're all set to start in on the fuel pump.
If, however, the rotor is pointing 180? away from the #1 terminal (the mark you made earlier), then it's currently at TDC of the EXHAUST stroke, so you'll need to rotate the crank 360? more. Once you turn it 360? more and the crank pulley notch is directly lined up with the TDC mark, AND the distributor rotor is pointing at the #1 plug wire terminal on the distributor, then you're good to go.
Clear as mud? <img src="/forums/images/graemlins/smile.gif" alt="" />
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: New member blah blah blah [Re: rxinhed] #892007 06/23/08 05:09 PM
Cochese Offline OP
Pay the shipping and I've got the dash grab handle for you from another red 87 Mitsu.
Welcome! <img src="/forums/images/graemlins/kewl.gif" alt="" />
You take paypal?
...it begins.
Re: New member blah blah blah [Re: CapnCrunch] #892008 06/23/08 05:12 PM
Cochese Offline OP
I know I'm a little out of the way, but I'd be happy to supply Cokes and lunch, as well as a few guns to gaze at if you wanna give me a hand. I think with your assistance it would go from a day project to an hour and a half once the parts get here. I live across the street from a Checker and a NAPA as well. <img src="/forums/images/graemlins/smile.gif" alt="" />
I work Wed. through Sat. currently from 0600-4 p.m. so any time outside of that, I'm good to go. I'd love to see your ride too. Just say when!
...it begins.
Re: New member blah blah blah [Re: rxinhed] #892009 06/23/08 05:16 PM
Cochese Offline OP
RXINHED,
I'll put together a parts list and see if I can deplete your Gen-I parts stock a little bit.
I know I'm going to need to find a new set of fenders, a hood and grill down the line, but for now, there are some little things missing I'd like to pick up.
I'll write up a little list this afternoon.
and... THANKS!
...it begins.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6527 MB (Peak: 0.7678 MB) Data Comp: Off Server Time: 2026-06-13 10:41:45 UTC
