Page 14 of 14 1 2 … 12 13 14
Re: New member blah blah blah [Re: fasteddy] #892120 07/03/08 04:03 AM
Cochese Offline OP
With a good fuel pump you should have no fuel delivery problems up to about 12psi of boost, which is probably a good safe limit on pump premium. She will run with v8 mustangs and the like at that level. Ricers, beware...
So a Walbro 255 and a Fuel Pressure regulator of some sort? Is this using the ghetto TB injection system on the quest or some MPI setup?
1987 Dodge Raider TSi
...it begins.
Re: New member blah blah blah [Re: Cochese] #892121 07/03/08 04:12 AM
Cochese Offline OP
I checked all of the external wire connections on the coil an they all appear to be intact. I didn't check the inside of the coil because I didn't want to remove it. I'm going to replace it with an OEM unit when I can order another. I just bought four NGK BPR6ES plugs tonight but Check didn't have wires or a coil OR a cap and rotor. I've decided to go OE for all of it, with NGK wires. I'll order it all soon.
The tach moved up from 0 to 1 over about 30 minutes and is now stuck at 2k. <img src="/forums/images/graemlins/confused.gif" alt="" />
Any ideas?
...it begins.
Re: New member blah blah blah [Re: Cochese] #892122 07/03/08 06:01 AM
don Offline
As far as I can tell, the tach senses the coil firing, there's no "detector" at the coil. When I changed to the 4.3 (6 cyl) from the 2.6 (4 cyl), I swapped in a Mitsu V6 Gen 1 tach, and simply ran the wire to the coil.
If your tach is "stuck", it may have an internal issue rather than a signaling issue.
I'm not the expert, but that's my understanding of it.
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: New member blah blah blah [Re: don] #892123 07/03/08 04:22 PM
highmtndesert Offline
I have a good turbo block for rebuild when your ready.
Well on my way to becoming that eccentric old man in every town.(crazy as a s#@thouse rat) With a yard full of desireable old vehicles that tells you, Sorry they're not for sale..... Someday I'm going to fix them.
Re: New member blah blah blah [Re: highmtndesert] #892124 07/04/08 01:33 AM
Cochese Offline OP
I see myself putting a motor together next summer. <img src="/forums/images/graemlins/smile.gif" alt="" />
I can't wait!
...it begins.
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.012s) Memory: 0.6189 MB (Peak: 0.6996 MB) Data Comp: Off Server Time: 2026-11-17 04:24:52 UTC
