EB's 261C cam will pass smog #892927 06/27/08 02:44 AM
stock87 Offline OP
For anyone wondering, yes, the 261C "crawler" cam will smog in Cali. My truck is running great, a shade lean at idle (given the high HC), but it still passed first try.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: EB's 261C cam will pass smog [Re: stock87] #892928 06/27/08 03:25 AM
A
anotherjeff Offline
Congratulations! You squeaked through, though. "142ppm", with 143ppm max, is close! (I believe "143ppm max" means "measured 143ppm fails", in CA)
Re: EB's 261C cam will pass smog [Re: stock87] #892929 06/27/08 05:54 AM
Jeepeater Offline
Any idea why the HC is high at 15mph? I just did the street RV head and 261c cam myself but haven't been smogged yet.
Re: EB's 261C cam will pass smog [Re: Jeepeater] #892930 06/27/08 06:14 AM
kewlynx Offline
FWIW, it helps if you do an oil change with the HC before you go in, esp if you are carberated.
Kali-- argh.
**ubi apis- ibi salus**
Re: EB's 261C cam will pass smog [Re: anotherjeff] #892931 06/27/08 06:17 AM
stock87 Offline OP
Noticed that too, huh? Hey, a miss is as good as a mile, right? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: EB's 261C cam will pass smog [Re: Jeepeater] #892932 06/28/08 05:32 AM
stock87 Offline OP
Sorry it took me a while to read your question correctly. The HC is high because the idle mix is set too lean. Rich would be high HC and high CO. I still don't fully understand the method for setting the mix without an EGA, but I've got it running pretty well I think. Good enough to pass anyway.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6108 MB (Peak: 0.6810 MB) Data Comp: Off Server Time: 2026-11-14 16:49:26 UTC
